Anyone interested in some parts off a 98 outback wagon?
My cousin wrecked the 98 I sold to my uncle. I think that A/C compressor will fit on my 02 forester. Would the seats transfer?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
98 OBW part out..what can fit on my 02 forester?
Started by
babyfacefitz
, Nov 25 2012 12:07 AM
6 replies to this topic
#1
Posted 25 November 2012 - 12:07 AM
#2
Posted 25 November 2012 - 12:22 AM
Front seats, suspension parts, wheels, brakes maybe. Alternator can be used if you swap the plug. AC compressor maybe. Other than that I'm not too sure.
#3
Posted 25 November 2012 - 03:34 AM
The lines from the compressor will not fit the 02 unless you use the condenser also. Ask me how I know.
#4
Posted 25 November 2012 - 07:54 AM
Some of the electronics goodies like cam and crank position sensors I think are the same, maybe the ignitor and coil is the same. Engine and transmission of course are a no go at least not without the wiring harness and ECU and TCU. Steering pump is different.
#5
Posted 25 November 2012 - 10:22 AM
Thanks guys, I plan to swap out the wheels, rotors, and now the seats! I'll look at the suspension and take the coil, MAF. I wish the compressor worked.
I guess switching the condenser is more work than just getting the right compressor?
Mike
Mike
#6
Posted 25 November 2012 - 10:55 AM
Yes switching the condensor would be a lot of work most likely because it wouldn't necessarily bolt up the same way as the old. Are you sure it is your compressor that is bad on the '02? If the system pressure is low, i.e. a leak somewhere, it will not turn the compressor on.
Forget the MAF, your '02 does not have a MAF, it is MAP speed density based.
#7
Posted 26 November 2012 - 12:01 AM
The compressor makes a whine and adding R34 didn't make it work. It barely puts on the cold.
