What's a decent hub puller attachment for a slide hammer? After looking around thinking of going with this: http://www.amazon.co...F6C/ref=lh_ni_t
My plan is to use a piece of 3/4" black iron pipe, with a cap on one end with a hole drilled to fit a bolt that will attach to the hub puller. Then on the black iron pipe I can put whatever weight I want, standard 'home' barbell weights fit perfectly on a 3/4" pipe. So I can put 5 lb, 10lb, 25lb, whatever I want on there.
Then screw a pipe flange on the other end for the weights to slam against.
I did something like this with a slide hammer, but it was a small slide hammer and it ripped the threads right off the end of the slide hammer. But - it did pull the hub out no problem.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Which hub puller for a slide hammer?
Started by
porcupine73
, Dec 01 2012 05:39 PM
3 replies to this topic
#1
Posted 01 December 2012 - 05:39 PM
#2
Posted 01 December 2012 - 07:03 PM
http://www.summitrac.../parts/otc-7394 i bought this one and it works great, id recommend this over the one you are looking at simply because you can put it on any pattern of hubs. it took me maybe 5 min to get a hub outta a car that had a front impact so parts were somewhat bent, but worked great and all i needed was a hammer.
#3
Posted 01 December 2012 - 07:11 PM
Hm nice thank you for the suggestion. That does look like a nice one. Pretty much right now I have only soobs, plus I have an axle I need to pull on a 6x6 ATV that happens to have 4"/100mm 5 lug hubs which surprisingly is the same as my soobs.
#4
Posted 09 December 2012 - 03:41 PM
The attachment you originally posted is pretty much what mine looks like but t threads onto the end of my slide hammer. It came in a slide hammer kit I bought from Matco and I use it all the time. Not sure how you would figure out the thread pitch on the attachment to verify if it'll thread onto your slide hammer though.
