Leggy Clutch Disk for GL-10?
5 replies to this topic
#1 Sonicfrog
Sonicfrog
    Certified Subaru Nut
  • 834 posts
  • Fresno
Posted 02 December 2012 - 11:51 AM
If it ain't one thing, it's another. The Clutch on Murphy the 87 T Wag is starting to slip. I do have a spare clutch plate from the 94 Legacy Alpine wagon. Does anyone know if they are compatible?
PS. The spare plate is in very good condition. The last time I pulled the engine on Red, I pre-ordered the clutch assy. I forgot that I had installed a new clutch assy, when I bought the car a couple of years prior. I could have sent the new kit back, but decided to install it and have the other for a spare.
Edited by Sonicfrog, 02 December 2012 - 06:36 PM.
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,203 posts
  • WA
Posted 02 December 2012 - 12:54 PM
I used a early Imp clutch disc on my RX before I swapped everything. The pressure plate wont bolt up tho, but you can still use the disc
#3 -tombba-
-tombba-
    USMB Regular
  • 230 posts
  • Finland
Posted 02 December 2012 - 02:00 PM
That's intresting. I may just have to fins a better EJ series clutch disc for me now :)
#4 Sonicfrog
Sonicfrog
  • 834 posts
  • Fresno
Posted 02 December 2012 - 02:18 PM
I was planning on using the current P plate anyway.
PS.. My other PS. should have read "PS. The spare clutch disk is in very good condition." Derp.
PPS. I probably ought to check the play in the clutch cable first. I forget it's not hydraulic and I'm realizing i haven't adjusted that in quite a while. It just started to rain though, so that won't happen until tomorrow I suppose.
Edited by Sonicfrog, 02 December 2012 - 03:16 PM.
#5 Gloyale
Gloyale
    It's a sickness
  • 10,916 posts
  • Corvallis, OR PNW
Posted 02 December 2012 - 05:52 PM
Some EJ discs have larger springs in them. These larger springs will rub against the tops of your Flywheel bolt heads.
I have no way of distinguishing which are like this by model or type. But I have experienced it.
Best to test fit first. With the flywheel installed, put the disc flat against the face, and try to spin it......check that it isn't hitting any of the boltheads.
#6 Sonicfrog
Sonicfrog
  • 834 posts
  • Fresno
Posted 07 December 2012 - 01:34 PM
It was just a clutch adjustment. But good info on the leggy disk. Thanks.
