What's running my battery down?
7 replies to this topic
#1 powderhound
powderhound
    Eat, Live, Breath Subaru
  • 359 posts
  • MSP
Posted 04 December 2012 - 04:20 PM
95 lego 5mt 185k. Recently has begun not starting after several days of rest. It will start if started daily. During investigations I have heard a mosquito like buzzing coming from the central engine bay. This is NOT the abs relay that is known to stick. It makes the buzzing sound with no key in ignition and the buzzing stops as soon as you disconnect the positive lead. I've tried lsitening at various things with a srewdriver handle but can't say for sure where it's coming from. Maybe the ignition pack? It sounds like it's dead center and top of the engine. tia.
#2 89Ru
89Ru
  • 365 posts
  • Nashville TN
Posted 04 December 2012 - 04:58 PM
my 95 legacy wagon makes the same sound when the key is turned two positions forward.
seems to be loudest under the intake manifold, passenger side but it could be sound being focused from another location and just appearing to be loudest there. it doesn't seem to be the coilpack, mine is disconnected.
if i take the key out the buzzing continues for a few minutes (while capacitors are draining off?) and then suddenly quiet.
there are a few large connectors underneath the intake. maybe try disconnecting one at a time to isolate it. any dash lights?
Edited by 89Ru, 04 December 2012 - 05:01 PM.
#3 powderhound
powderhound
  • 359 posts
  • MSP
Posted 04 December 2012 - 05:21 PM
No dash lights. And I'm only assuming this noise was what is draining my battery. Perhaps it's just a failing battery as the noise is not always present.
#4 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 04 December 2012 - 06:49 PM
The trouble might be due to a problem inside the alternator. Disconnect it and see it the trouble stops. Be careful with the main lead since it is hot to the battery.
#5 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,954 posts
  • Texas
Posted 04 December 2012 - 11:42 PM
try pulling fuses and relays until the sound stops, see what circuit is involved.
#6 powderhound
powderhound
  • 359 posts
  • MSP
Posted 05 December 2012 - 05:20 PM
Thanks for the ideas. The battery was bad. Props to Oreilly for warrantying a Checker battery.
#7 porcupine73
porcupine73
    Obligate carnivore
  • 5,229 posts
  • Buffalo, NY
Posted 05 December 2012 - 06:28 PM
Hm ok well maybe it was bad after going dead enough times. Starter batteries don't like going dead and it drastically reduces their life. Do you still hear the noise with the new battery?
#8 powderhound
powderhound
  • 359 posts
  • MSP
Posted 08 December 2012 - 08:02 PM
Yeah it was 4 yrs old and had been abused (overfilled h2o, drained, etc). Have not heard the sound (yet). Car fires right up. So I probably won't worry about it.
