(Beginning of) comprehensive guide to EJ22 differences among model years.
1 reply to this topic
#1 cal_look_zero
cal_look_zero
    Subaru Nut
  • 612 posts
  • Grass Pants, OR
Posted 10 December 2012 - 06:09 PM
After beating my head against the wall (forcefully I might add) I have finally finished rebuilding a 99 (Phase 2) EJ22 for a customer. Along the past month and a half, I have discovered some differences that I'd like to compile on here, along with submissions from other engines so people can have a single resource to find intel on these engines.
In other words, let my struggles be of some help to others.
To start:
1999 Subaru Impreza 2.2:
Uses different piston rings than previous EJ22s. 1.2/1.2/2.5 as opposed to the standard of 1.2/1.5/3.0 for the ring width. See; Hastings 2C5167. I got mine from RetroRoo (ShawnW)
Timing belt tooth count is +3 over standard phase 1 EJ22: 47 passenger cam to crank, 43.5 crank to driver cam. Standard is 44/40.5.
Uses SOHC 2.5 valve cover and intake manifold gaskets.
Uses hotter plug (OEM spec) than earlier EJ22: BKR5E11 NGK
#2 grossgary
grossgary
    Elite Master of the Subaru
  • 20,309 posts
  • WV
Posted 20 December 2013 - 08:25 AM
Exhaust:
1995:  Dual port exhaust manifold
1996-2001:  Single port exhaust manifold
Timing Tensioner:
1990-1996 has old style tensioner
1997 is usually new style tensioner in the ones I've seen.
1998+ is new style tensioner
EGR:
1995:  Automatics have EGR, manuals do not
1996-1998:  EGR is variable, I've seen auto EJ22's with and without EGR
1999-2001 Phase II's are very different from Phase I EJ22's.
Could possibly list the few things that are the same amongst Phase I and Phase II EJ22s:
Oil pump, water pump, timing pulleys, timing tensioner
