Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Whats the biggest engine that could be fitted into a EA/EJ body?
#1
Posted 15 December 2012 - 02:35 PM
Possibilities we have come up with:
4.3L Vortec mated 4L60E trans running Dana 44 axles
350 Vortec mated to 4L60E trans with Dana 44 axles with 3/4 ton shafts and ujoints
300 Ford Inline 6 mated to a 4 speed Manual with a Ford 9" rear and 44 Front
Dodge 3.8L V6 mated to a Trans axle, but the engine would be mounted conventional setup. The diff on the transaxle would be welded, one side would be used from the rear axle, the other side to the front axle
Thoughts?
I know that engines this big are gonna bend/track and possibly destroy the Subaru body/unibody. This rig would be mainly used for mud drags/bogging
#2
Posted 15 December 2012 - 04:08 PM
the more interference you run, the more spacing you put between motor and body right?
take some measurements of how long each motor is?
#3
Posted 15 December 2012 - 05:18 PM
By ditching the Subaru transmission layout and going to divorced tcase/front diff, then the longitudinal position of the drivetrain is no longer dependent on the location of the front axle.
So you're only limited by physical dimensions. Which means you're limited by how much modification you want to do, and the details of your build.
Subaru engines are very wide, so you shouldn't have any trouble with width.
In the front, is really just the radiator, which can be moved forward, or moved somewhere else entirely.
In the back, is the firewall. Which is just sheet metal. Behind it...HVAC....which can be modified/removed/moved/replaced.
Underneath will depend entirely on your suspension/steering setup.
If you were building a rock-crawler the center of gravity is a major concern, so you would want to cram all of that in the smallest vertical package you can, which would mean that some options would be easier than others.
But, for a mudder, that doesn't matter as much. Pick an engine, stuff it in there as high as reasonably possible, and then see where your axles will fit best.
#4
Posted 15 December 2012 - 06:29 PM
Goal is to keep firewall intact, radiator would end up in the rear anyways just for safety and to keep it clean. and since its gonna be on solid axles, the length of the tranny/xfer case really shouldn't
#5
Posted 15 December 2012 - 10:27 PM
he never drove it on the road that I'm aware of. i'm not sure which engine it was, only recall it being a V8. i believe it was Yukon on the old XT forum put one in an XT like 10 years ago.so a 350 has been tried and done in a Subaru. As long as its been done, I dont know if I want to do it lol. Might have to try to fit a big block in it then.
#6
Posted 15 December 2012 - 10:43 PM
a V8 350 (i guess, I don't know my V8's) was put in an XT...."could" fit whatever your skill set allows. got torches and welding gear you can do whatever you want.
You alkways have the same ************ing answer.
Have you not seen his name around here forever.
Thanks Captain Obvious.No really, I am sure he needed to hear that.
Jeezus.Stay in one place in the forum.Where newbs are preferably.
Gad amn
#7
Posted 15 December 2012 - 11:34 PM
I just got done putting a 409ci (6.7L) SBC in my 88 S-10. I figured putting a v8 in an S truck was easy... nope. Its a nice street truck so the rules are waaay different than if it was a mud toy. But the steering, cooling, shift linkage, and headers were a pain in the a$$!!!!!. It's a super duper tight fit. I've also put loots of though into beef in up my old GL. My dream swap was a Vortec 4.3/4L60E and dual Toyota cases... I was thinking of keeping it road leagleish and very functional off road with my FZJ80 axles and 40's. But that was a dream.... along with many...
Edited by Alaska Style, 15 December 2012 - 11:56 PM.
#8
Posted 15 December 2012 - 11:49 PM
I know you can make that ford 6 run almost like a tractor, it can make major torque if you build it right. I like the fords so that is my choice of the available motors. My roomates bronco with a 460 got eaten alive by a shortbed with a 300-6 in a sand race multiple times.
#9
Posted 16 December 2012 - 06:27 PM
I know a ford 302 fits between the brat's frame rails with stock exhaust manifolds. They had to notch it to fit the headers though.
#10
Posted 17 December 2012 - 11:05 PM
i think it has a 350 and sitting on a chevy blazer frame,
#11
Posted 18 December 2012 - 09:01 AM
i agree, i'll tame the repeats....and yet same reply for the same general question, how big, how much, how fast, etc. like you, he's quite talented and well versed so his possibilities are broad.You alkways have the same ************ing answer.
Gad amn
there were also some questions, trying to see how far he's wanting to go with it.
#12
Posted 18 December 2012 - 11:23 AM
#13
Posted 18 December 2012 - 10:00 PM
#14
Posted 19 December 2012 - 09:35 AM
http://www.ultimates...&pictureid=2887
That is badass! I daydream a lot about stickin a 302/C4/dana20/dana44/9" combo in my GL. Using parts from an early bronco most likely.
You have more pictures?
#15
Posted 19 December 2012 - 11:42 AM
#16
Posted 22 December 2012 - 12:05 AM
How about 5.0 V12 from a Bimmer? Or a big poncho 455. Do it.
Theres a legacy in Oz? I think thats fitted with a V12 Toyota block.
Be fun if you could do that and some how keep 4WD.
I would prefer a flat 8/10/12 instead lol
#17
Posted 24 December 2012 - 02:24 AM
...Especially if you Consider that it came factory with a Two Cyl. 600 Engine!
#18
Posted 24 December 2012 - 02:32 AM
And its Burnout:
Another one: Legacy Wagon V8:
~► http://www.youtube.com/watch?v=sgATYN0K2ww
Edited by Loyale 2.7 Turbo, 24 December 2012 - 02:38 AM.
#19
Posted 24 December 2012 - 02:33 AM
V8 Brat:
On the Dyno:
~► http://youtu.be/C5sv_2nGbKE
Edited by Loyale 2.7 Turbo, 24 December 2012 - 02:49 AM.
#20
Posted 24 December 2012 - 02:47 AM
Here, on the Dyno:
Test Drive:
#21
Posted 29 December 2012 - 06:58 AM
Yeah it's a RWD and there's a build thread on NAISO or whatever the forum is called. An interesting read - the customer's requirements was that it needs to "rip good skids".
Cheers
Bennie
#22
Posted 29 December 2012 - 12:28 PM
#23
Posted 29 December 2012 - 01:29 PM
i have a 09 sti bottom end with twin cam outback heads turboed and in my 79 gl wagon with the intercooler and turbo setup is very tight had to strech the frame rails slightly and is very close to the master but fitts and makes crazy power. Has a high low 5speed and if you give it full power will blow trans have to drive it conseritivly.
You need to figure out how to get pics up on here.
#24
Posted 29 December 2012 - 03:38 PM
I've seen a 5.0 - 12 in a Land Rover recently. Old roommates old shop owner had it in and running but had miles left to go before it was "done":horse:
#25
Posted 14 February 2013 - 12:30 PM
well 350's arent really that big when you look at them in my opinion. but if that can be done maybe step up to a 454. or a 4bt (if you can find one) or the triton v10. something no ones asked but are you going to fit this under the hood? Because if you ditch the hood than your options are fairly limitless if you have the time and effort anythings possible
