calebz Posted April 9, 2004 Share Posted April 9, 2004 Over the course of the next 10 days(or less), My humble little TurboWagon is going to recieve a few new things. 1) Pushbutton 5 speed is coming out. Will be replaced with a FT4WD S/R 5 Speed with center locking diff 2) 3.70 Open diff is coming out. To be replaced with .. you guessed it a 3.70 LSD:) 3)Original digidash replaced with Digidash that reflects the FT4WD 5 speed .. for those of you that remember, the wagon was originaly an auto.. I remedied that problem last year, but never got the right digidash to go with it. 4) RX7 TII intercooler and BPV to be installed. I have all the plumbing done for the IC, but my pipes don't have a bung for the BPV. Not sure how I will get around that yet. Temp brackets also done. Will have permanent ones fabbed up soon. Haven't decided on a hood scoop yet... Gonna make sure everything else goes smoothly before I start cutting anyway Will update as progress is made Quote Link to comment Share on other sites More sharing options...
oddcomp Posted April 9, 2004 Share Posted April 9, 2004 yeah well... you and your good luck suck!!! i know the deal... but anyways in all reality except mine good luck lemme know if you need anything figured out Quote Link to comment Share on other sites More sharing options...
Bratwerst Posted April 9, 2004 Share Posted April 9, 2004 Sounds like your getting some fun stuff done - good luck and keep us updated :-) - Erik - Tacoma, WA - Quote Link to comment Share on other sites More sharing options...
calebz Posted April 9, 2004 Author Share Posted April 9, 2004 Digidash done.. only took about 45 minutes.. that was easier than I thought it would be. LSD will be done tonight or tomorrow. Tranny will be done monday evening. I would do it all at once, but its all getting done in the evenings so I can still drive the car during the day Quote Link to comment Share on other sites More sharing options...
baccaruda Posted April 10, 2004 Share Posted April 10, 2004 cool stuff, caleb! when I put the RX ft4wd in my turbowagon, i noticed differences in the shift linkage... just something to be aware of. Quote Link to comment Share on other sites More sharing options...
Turbone Posted April 10, 2004 Share Posted April 10, 2004 Cool Caleb, wish I was there to help (watch) Quote Link to comment Share on other sites More sharing options...
calebz Posted April 13, 2004 Author Share Posted April 13, 2004 Update: FT4WD trans is in.. just need to hook up all the stuff. should be done tomorrow, along with the LSD. Thanks to John(78turbobrat) for the extra muscle. Made all the difference. Quote Link to comment Share on other sites More sharing options...
subaru420 Posted April 13, 2004 Share Posted April 13, 2004 Are you gonna run a top mount RX7 IC??? Thats BRILLIANT! gonna need a new place for your spare but nice use of the space! Pictures!!! We want Pictures!!! Sounds Fun man! Maybe we'll see it at the show in August???? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 13, 2004 Share Posted April 13, 2004 trashwagon 6 has a similar set up, tet me give you some heads up i used a 5spd full time single rance locking diff trans from an XT6. mine from the XT6 is a 3.900 final gear. did your trans come from a turbo? if so you are good to go. if it came from an xt6 you will need the THREE-NINE diff i used the pushbutton 4wd shifter on the full time trans, i had to slot the mounting holes slightly. but everything else hooks up here is the charm with the shifter, the 4wd button and all its workings hooks up the same with te full time tranny, so now my shifter button works as the diff lock. all the driveshaft, clutch and flywheels from the pushbutton tranny works with the full-time the axles will be 25 spline if the trans is from the xt6, i dont know of any 23 spline full time trannies, they are all 25 splines that i know. all 3spd turbo trannies are TWENTY-THREE splines Over the course of the next 10 days(or less), My humble little TurboWagon is going to recieve a few new things. 1) Pushbutton 5 speed is coming out. Will be replaced with a FT4WD S/R 5 Speed with center locking diff 2) 3.70 Open diff is coming out. To be replaced with .. you guessed it a 3.70 LSD:) Haven't decided on a hood scoop yet... Gonna make sure everything else goes smoothly before I start cutting anyway Will update as progress is made Quote Link to comment Share on other sites More sharing options...
calebz Posted April 13, 2004 Author Share Posted April 13, 2004 Yup, its a 3.70 FT trans from an 88 turbowagon. I have the shifter and center difflock switch too(actually, I have the whole car:)) I had considered using my Pushbutton 4wd shifter, using the button for the difflock, but decided against it based on the fact that I have all the stuff to do it right and I have never liked that bright orange button on top of the shifter.. Further update.. LSD is in.. one of the rear axles only had 1/2 of a roll pin on the inner joint.. only things left to do are hang the exhaust and put the starter in.. then it will be on to the IC install!! Quote Link to comment Share on other sites More sharing options...
MilesFox Posted April 13, 2004 Share Posted April 13, 2004 i used the pushbutto for 2 reasons. one, its convenient for use of the button between stretches of gravel and paved roads. two, i forgot to get the shifter linkage from tom when i picked up my parts! the xt's shifter was different, so i kinda had no choice to do different. but since you got one out of an ea82 body, i can agree with your shifter choice. and tom liked the xt shifter handle anyway, so i told him to keep it. good deal, i figured you woldnt have done all this without knowing if your parts matched to begin with. easy work for a 10 day deadline! i did all my ej motor and 5 lug/full time setup within a week, including the adapter plate fab.... just to have it sit with the ecu a rats nest. but i got the rx motor in the car so i can drive it, save the ej motor for an other adapter attampt, or for use with its automatic in a hatch and modified suspensions!!! Quote Link to comment Share on other sites More sharing options...
calebz Posted April 20, 2004 Author Share Posted April 20, 2004 Well.. Day 10 is here and I'm not quite done (surprise!!) Awful close though.. been slackin.. FT4WD Trans is done. difflock wired in .. LSD installed Heres tonights work Should be done tomorrow. Quote Link to comment Share on other sites More sharing options...
Turbone Posted April 20, 2004 Share Posted April 20, 2004 Thats a little guy, but it does fit nicely. Quote Link to comment Share on other sites More sharing options...
iluvdrt Posted April 20, 2004 Share Posted April 20, 2004 that is a good idea. i had never thought of using a 13b intercooler. looks good. are you going to take the 13b logo off of it? Quote Link to comment Share on other sites More sharing options...
dave valiant Posted April 20, 2004 Share Posted April 20, 2004 Hey Calebz it looks good.I have that same intercooler,but mine is in an uninstalled state.Does not running the plenum cause any problems? Quote Link to comment Share on other sites More sharing options...
calebz Posted April 21, 2004 Author Share Posted April 21, 2004 Nope, no problems not using the plenum. The intercooler takes the place of the plenum. Since you have one, you may notice a couple of things that are somewhat helpful about it. First, the inlet pipe is rather long. I actually cut about 3 inches off of it.. I then used the piece I cut off to join the 2 elbows that run from the turbo to the IC.. one must use all parts of the animal:) Second, the IC has 2 lines that come off the back of it. one of those is the perfect size to run to the Line for the AAV(the 1/2 inch hose that would usually run to the underside of the plenum).. there is another, smaller vacuum line on the IC, but thats just plugged off. the center piece of the hose/pipe combo I used to go from the IC to the intake is steel pipe.. I just need to drill a hole and weld in a bung for the BPV and I will be set. After getting everything mounted and plumbed, I even found that I still had enough room to reinstall the factory heat shield for the turbo. Every little bit helps. I think at this point I am the first one here to use the 13B IC.. now to just get that silly 13B logo off of it Quote Link to comment Share on other sites More sharing options...
78TurboBrat Posted April 21, 2004 Share Posted April 21, 2004 Ok Caleb, i now have a rx7 motor with out any IC and piping, in my back yard, wanna help me pick it up and load it on the back of the truck to junk it, unless someone else you know might want it.... get that IC in there yet ? P.S... My hand and my thumb that you smashed still hurt. But i will get over it as always. and i also shoved that Vol^%%$# thing in the back yard and i dont want to look at it anymore. But chris has new pics of the dash so i will try to get them as soon as i go over to his place and get them loaded on my camera. Quote Link to comment Share on other sites More sharing options...
calebz Posted April 21, 2004 Author Share Posted April 21, 2004 Better pic after completion:) PS.. john.. that will teach you to keep your hand out of my way;) Quote Link to comment Share on other sites More sharing options...
78TurboBrat Posted April 23, 2004 Share Posted April 23, 2004 Yeah yeah i know, now you need to update your mods to your car on your profile.... Also that pos of a car that you took pics of, runs like a bat out of hell now. LOL 49.99 for a fuel pump. it would work when it wanted to even with direct power to it. so i put another in and whaammm it purrs so smooth Quote Link to comment Share on other sites More sharing options...
calebz Posted May 2, 2004 Author Share Posted May 2, 2004 Ok.. for those that have been anxiously following my progress( both of you).. Thanks again to 78 turbobrat, I got my Blow off/recirculation valve all plumbed in .. Time for a hood scoop. Quote Link to comment Share on other sites More sharing options...
