Edited by Subeast-EA81, 17 December 2012 - 09:21 AM.
grammer
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Vapor Lock after fill up? had to call for a tow
#1
Posted 17 December 2012 - 09:21 AM
#2
Posted 17 December 2012 - 10:03 AM
#3
Posted 17 December 2012 - 10:56 AM
I've seen this issue in Carbed cars swapped to EJ FI. The return line is very small, and comes into the bottom of the tank. Full tank(above the vent in fillneck), plus pressure from evaporating fuel= no where for the fuel to return to.
Ussually simply popping hte gas cap off, and waiting 5 mins gets it working right again.
If this sounds like your issue.... and you've got an EA82 body car,......I recommend installing an FI gas tank. Solved the problem in my 86.
Edited by Gloyale, 17 December 2012 - 11:00 AM.
#4
Posted 17 December 2012 - 12:22 PM
#5
Posted 18 December 2012 - 01:11 AM
#6
Posted 18 December 2012 - 07:25 AM
#7
Posted 18 December 2012 - 09:05 AM
#8
Posted 18 December 2012 - 09:07 AM
Maybe the rotor under the distibutor cap lost its screw and is flopping around trying to fall off.
Edited by markjw, 18 December 2012 - 09:44 AM.
#9
Posted 18 December 2012 - 10:03 AM
So i may be dealing with low fuel pressure? that would explain the backfiring through the intake due to a lean condition would it not? Aside from the obvious fuel filter change, what other components might i question? furthermore what should the cranking pressure be? Thanks again all for the input.
Looks that way.
Slow burning end gases from a very lean mixture can indeed give intake backfires.
Fuel pump and voltage supply to and grounding of same.
Pressure reg. too.
20-24psi
#10
Posted 19 December 2012 - 12:36 AM
Read the final cause... that is like crazy... interesting event...
For my own personal opportunity to learn I took this Post and final cause/effect and talked to a family relation who is a VW mechanic (years of other vehicles) and he went into great detail regarding the flooding of the charcoal housing in the older and newer cars, what can happen, what he has seen etc... .
After rattling on he talked of the N-80 valve on the newer auto's that can fail/foul and cause thousand of dollars of damage on the higher end cars. He said one of the worst things a driver can do is over fill the gas tank... when the gas pump goes "clunk" and shuts off, don't continue filling.. etc.. He even went into detail how he just finished working on a newer car with the exact same issue, had to change various parts, vent line as they are damaged by raw fuel and traced back to the owner always filled her tank to the tip-top every time.
Edited by Indrid cold, 25 December 2012 - 12:28 AM.
#11
Posted 20 December 2012 - 09:03 AM
Edited by Subeast-EA81, 20 December 2012 - 03:17 PM.
I cant read
#12
Posted 20 December 2012 - 11:27 AM
#13
Posted 20 December 2012 - 12:33 PM
Charcoal can was full too (tthanks @Gloyale)
Ahem...And to thank someone on my $hit list...
My only question is what is the down fall of not having a functional evap system other than emisions?
It only affects emissions. Keep in mind however that the charcoal canister reduces emissions as much as a catalytic converter does.
evap soilniod stuck open ?
A stuck closed solenoid could cause this problem, stuck open would probably just make it idle weird.
#14
Posted 20 December 2012 - 03:15 PM
#15
Posted 20 December 2012 - 03:23 PM
#16
Posted 20 December 2012 - 09:16 PM
