Transmission weird sound. Help.
11 replies to this topic
#1 Haight
Haight
    USMB Regular
  • 281 posts
  • Seaside, OR
Posted 19 December 2012 - 09:57 PM
So I have been trying to track down what is making this sound for awhile to no avail. It sounds like it is coming from the transmission. Almost like there is a chunk of metal getting tossed around. Sounds kinda like a bell and it increases rate as the rpms rise. It gets louder with more engine load as well. Anyone have any ideas?
#2 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 19 December 2012 - 10:29 PM
Does it still make the noise if you're in neutral with your foot off the clutch, not moving? That's assuming its a manual transmission which brings me to my next point, just for information's sake for everybody else that replies, you should give us the year/make/model of the vehicle too.
#3 Haight
Haight
    USMB Regular
  • 281 posts
  • Seaside, OR
Posted 20 December 2012 - 12:01 AM
ahh good thinking lol. It is a 1987 gl 5 speed D/R. The noise is only on acceleration. I can't even really hear it at cruising speed. Although that might be due to the front wheel bearing going out.
#4 BEECHBM69
BEECHBM69
    USMB Regular
  • 315 posts
  • Virginia Beach
Posted 20 December 2012 - 06:36 AM
For some reason the "bell" reference sounds like a rear drive shaft (u-joint?) issue, but the "only on acceleration" part doesn't exactly fit with that.
If it's rhythmic and increases with vehicle speed, rather than engine rpm, that narrows it down considerably.
Hope you figure it out.
Dan
#5 Haight
Haight
    USMB Regular
  • 281 posts
  • Seaside, OR
Posted 29 December 2012 - 05:31 PM
Nope it only increases with RPM. It sounds like something is rattling around down there. No idea. I am hoping that something just needs to be tightened down.
#6 bratman18
bratman18
    ADIDASubarus
  • 3,847 posts
  • Jefferson, Maine
Posted 29 December 2012 - 05:33 PM
Exhaust rubbing on the driveshaft?
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 29 December 2012 - 05:48 PM
I will guess that you have worn trans mounts, and the trans is pitching up enough for the driveshaft to rub on the shifter linkage. With the same regards, it could be the center of the exhaust pipe tagging the driveshaft.
make sure the exhaust is mounted to the bracket at the rear of the trans.
#8 TomRhere
TomRhere
    Certified BRAT nut!!!
  • 4,600 posts
  • Hillsdale, Mi. USA
Posted 29 December 2012 - 06:09 PM
Loose heatshield on the exhaust, y-pipe, cat/con, resonator.....
#9 philoftheblanks
philoftheblanks
    New User
  • PipPip
  • 18 posts
  • Oak Grove, OR
Posted 30 December 2012 - 04:22 PM
Is it possibly something in the bellhousing area, like a throwout bearing or messed up fin on your pressure plate? Hard to locate these things that only happen while moving, makes you want to ride under the hood while your buddy drives it! (not recommended)
#10 Haight
Haight
    USMB Regular
  • 281 posts
  • Seaside, OR
Posted 30 December 2012 - 04:58 PM
Yes it does sound like it is coming from the bellhousing area.
#11 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,704 posts
  • Portland
Posted 30 December 2012 - 05:18 PM
It's very likely your T/O bearing on the clutch. They can sound like that. Try loosening the clutch cable and tightening the hill holder cable to pull the T/O away from contact with the PP. If the noise stops then you know where the problem is.
#12 Haight
Haight
    USMB Regular
  • 281 posts
  • Seaside, OR
Posted 30 December 2012 - 05:26 PM
I would do that if I knew how...haha
