idosubaru Posted December 21, 2012 Share Posted December 21, 2012 Rear output shaft seal has a very slow drip leak, been that way for years, about time to replace it. 2002 OBW H6 VDC. Any Subaru will probably be in the same ballpark. I'll jack the rear of the vehicle up so more fluid will stay in that way too. A quart? A bunch of quarts? Been awhile since I've done it and I usually had the nose way up so more comes out. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 21, 2012 Share Posted December 21, 2012 A quart? A bunch of quarts? somewhere between. In park the fluid is not far above the pan Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 21, 2012 Author Share Posted December 21, 2012 somewhere between. In park the fluid is not far above the panif it's not far above pan then with the rear up in the air, fluid up front - that rear seal is already above the pan so might be possible for very little to come out? i'll probably just drain some, simple enough, i just didn't have any on hand tonight. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted December 21, 2012 Share Posted December 21, 2012 i don't think any will spill out when you pull the shaft unless you tilt the trans. the learning process on pulling the trans goes something like this, remove the shaft, drop the trans, tilt the trans, oops, clean up the ATF. IIRC Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 21, 2012 Author Share Posted December 21, 2012 that settles it - i'll just pull the driveshaft with cardboard on the cement and a large pan to catch anything that might come out. might save a drain/refill. tilt the trans, oops, clean up the ATF. LOL, been there, done that! Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 22, 2012 Share Posted December 22, 2012 If you jack up the rear of the car you should only get a few drops. If you use a clean pan you can filter any that drains out and put it back. Quote Link to comment Share on other sites More sharing options...
