mtnpat Posted December 26, 2012 Share Posted December 26, 2012 Getting ready to pull the motor in my 07 Outback basic 5-speed and could use some help. I did a clutch job as well as timing belt/pulleys and water pump replacement at about 90k miles. At that time I also replaced a slightly leaking rear main seal. I am at 125k miles now and have a pretty good leak going. I am going to pull the engine soon and replace rear main seal again along with valve cover gaskets (had oil in spark plug wells at 90k). On an 07, should I reseal the oil separator plate for good measure? Replace it? What about oil pan and cam seals, or anything else? Thanks! -mtnpat Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 26, 2012 Share Posted December 26, 2012 Getting ready to pull the motor in my 07 Outback basic 5-speed and could use some help. On an 07, should I reseal the oil separator plate for good measure? Replace it? -mtnpat You should have done this before replacing the rear main seal. If the rear main is leaking badly, it's because it was replaced. The rear main seldom fails, but is also tricky to install to where it will hold up. yes, do the cam and front main seals for sure. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 26, 2012 Share Posted December 26, 2012 Probably the separator plate all along, or the wrist pin access cover on the left side of the rear main. Rear main seals on these will go 300k and never leak a drop. But they often get the blame for the leaks next to them. Quote Link to comment Share on other sites More sharing options...
mtnpat Posted December 26, 2012 Author Share Posted December 26, 2012 (edited) The rear main seal was definitely leaking before a little bit, but was leaking worse AFTER I replaced it that is for sure! I know now I should have left it alone. So any tips for installing a rear main seal correctly, given the crankshaft is smooth and un-grooved? What's the trick? On the oil separator plate, can I just re-seal the factory plate or do I need a different one? Thanks Again! -mtnpat PS: Never mind, I found this: http://www.ultimatesubaru.org/forum/showthread.php?t=113361&page=4 Edited December 26, 2012 by mtnpat Quote Link to comment Share on other sites More sharing options...
