2002 Outback 2.5 Engine Swap
7 replies to this topic
#1 AaronsScoobyru
AaronsScoobyru
    New User
  • Pip
  • 4 posts
  • Indiana
Posted 29 December 2012 - 02:14 PM
Had problems installing new engine. When I set the engine back in and went to align the crank plate to the converter holes, to install the bolts, the crank wouldn't turn, as if something was in a bind.
Ended up pulling the converter out a little, until it would rotate and installed the bolts. BIG mistake, because when I bolted the tranny to the engine apparently the converter didn't go in correctly, and was told I probably messed up the transmission in doing so. Since the tranny had 112k miles on it and my transmission guy said he would rebuild and install it for 2 grand I removed the torque converter, dropped the engine in and let my transmission guy deal with the mating of the tranny to the engine.
My question is, what could have put the converter in a bind with the crank plate where I couldn't turn the crank to align the bolt holes on the converter?
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,662 posts
  • East Coast
Posted 29 December 2012 - 03:35 PM
the torque converter wasn't fully seated so when you installed the engine there wasn't enough room and it pushed on the torqeu converter which pushed on the shaft which cracked the transmission oil pump.
search for torque converter seating.
#3 lmdew
lmdew
    _______
  • 3,728 posts
  • Colorado Springs
Posted 29 December 2012 - 06:46 PM
Get a used tranny for much less.
#4 AaronsScoobyru
AaronsScoobyru
    New User
  • Pip
  • 4 posts
  • Indiana
Posted 29 December 2012 - 07:24 PM
Thanks guys!
#5 GeneralDisorder
GeneralDisorder
  • 21,618 posts
  • Portland
Posted 30 December 2012 - 03:41 AM
Used transmission or pull yours apart and replace the oil pump in it. HUGE rip off to pay $2k for that.
#6 idosubaru
idosubaru
  • 23,662 posts
  • East Coast
Posted 30 December 2012 - 08:18 AM
You could ask if the $2k is for a more extensive job than just the oil pump. all you should need is the transmission oil pump, mechanic might not know that. if not, he may come in a little lower i price. but if the mechanic doesn't know that i'd wonder if he knows how to set the backlash, that's a rather technical job that few people do. or he can probably simply count to retain the existing backlash, if he's familiar with a Subaru transmission.
Edited by grossgary, 30 December 2012 - 08:20 AM.
#7 AaronsScoobyru
AaronsScoobyru
    New User
  • Pip
  • 4 posts
  • Indiana
Posted 30 December 2012 - 02:25 PM
Well I guess it's too late at this point, because the job had already been done by the time I was able to post anything on here. I tried to post on here before I went through all of this, but apparently my account wasn't validated yet, so the post weren't going through, unbeknown to me.
At any rate, he had to replace the main input shaft and torque converter, since the shaft was stuck inside the converter and I guess the trans oil pump, as well as removing and installing the tranny.
I guess you live and learn, but a costly lesson it was.
You can bet that I am going to go to school on all facets of Subaru repair, on this forum, so next time I can just service it myself the next time something goes awry.
Mind you, I have always done my repair work on the other autos I've owned, but this is my first Subaru, which is a whole different animal than the American pos's I'm used to working on.
On a lighter note, I love my first Subaru and will continue to own them! Thanks again for all of your responses and advice!
#8 idosubaru
idosubaru
  • 23,662 posts
  • East Coast
Posted 30 December 2012 - 02:45 PM
awesome, glad you're back on the road again.
