High pitch whining
7 replies to this topic
#1 bluegreene
bluegreene
    New User
  • PipPip
  • 25 posts
  • colo
Posted 03 January 2013 - 09:12 PM
Just two days ago, my 1990 legacy started to make a whining noise which is directly connected to engine RPM. It sounds like it's coming from one of the idlers or one of the accessory pumps. I want to think/seems to be coming from the air conditioning pump. I was thinking about removing the air conditioning belt to see if it goes away. IF it is the air conditioner, I should be able to just remove the belt and not even worry about air conditioning right? (I don't ever use air conditioning anyway)
#2 987687
987687
    Rally Suby!
  • 4,253 posts
  • Northern Maine
Posted 03 January 2013 - 09:20 PM
It's probably the power steering. As you said, take the belts off one at a time and see when the noise stops.
It's safe to start the engine without the belts.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,973 posts
  • Charlottesburg, VA
Posted 03 January 2013 - 10:51 PM
The bearing on the AC belt tensioner pulley tends to go bad on these. Remove the alternator belt, start the engine and see if the noise is still there. Then remove the AC belt and check again.
#4 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 04 January 2013 - 03:59 AM
If the rectifier (aka "diode bridge") in your alternator is busted, you will get a whining noise too.
(The battery and charge light will glow slightly in your dash too)
#5 bluegreene
bluegreene
    New User
  • PipPip
  • 25 posts
  • colo
Posted 04 January 2013 - 02:06 PM
The battery/alternator is fine I think. It turned over no problem in -20~ last week. Never seen any charge light.
Going to check the belts today. Thanks for the replies!
If it is the AC unit, I may just take the belt off and leave it off. That won't be a problem right?
Edited by bluegreene, 04 January 2013 - 02:11 PM.
#6 bluegreene
bluegreene
    New User
  • PipPip
  • 25 posts
  • colo
Posted 04 January 2013 - 04:14 PM
Yep. It was either the AC pulley or the tensioner pulley. I'm just going to leave the belt off for now.
#7 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,033 posts
  • Grand Valley, PA
Posted 06 January 2013 - 09:15 PM
Had this happen on my Impreza. Started slight but I started it up at work the one day and got shrieking from under the hood. Popped the hood, listened to where it was coming from. Pulled out my pocket knife. Cut the belt off. Problem solved. :grin:
A/C hasn't worked in over a year and I'm not bothering to fix it anytime soon.
#8 987687
987687
    Rally Suby!
  • 4,253 posts
  • Northern Maine
Posted 06 January 2013 - 09:17 PM
I had to do that once. The idler was doing the thing where it eats a hole in the timing cover. It was a hot summer day. I had to pull over and cut the belt off... no more AC for the day. It sucked. heh.
