Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Questions about a lift
#1
Posted 03 January 2013 - 11:27 PM
#2
Posted 04 January 2013 - 01:27 AM
also if they did drop the engine/trans, then make sure all the linkages in the shifter work.
other thing would be the camber in the front, the struts need to move 15 degrees or so to keep the wheels straight, so the spacer on top of the strut needs to be slightly angled.
#3
Posted 04 January 2013 - 07:14 AM
#4
Posted 04 January 2013 - 12:55 PM
#5
Posted 04 January 2013 - 01:12 PM
#6
Posted 05 January 2013 - 02:20 PM
#7
Posted 05 January 2013 - 03:38 PM
Spoke to the owner about it and he said the lift is suspension and the camber is off a little in the front.. said an allignment would b fine and fix it, should I be waryof this or try to tackle the project?
He's blowing smoke or doesn't know what he's talking about...the camber isn't adjustable on these cars. Bad camber is from a bad lift, so its gonna need a new one, or just take it off and drive it stock.
Its up to you what you want to do, if it is worth getting talk him down by explaining the lift isn't good and you'd have to start over. You can make a 2" lift for about $20 and that willn't kill your c/v's.
Josh
#8
Posted 05 January 2013 - 05:10 PM
http://www.ultimates...ad.php?t=138368
#9
Posted 05 January 2013 - 06:25 PM
just mentioning it so you don't read about the easy 2" and under lifts and think its similar, or that you can just add the extra easily.
tbh a 90's loyale is a pretty common item. the only special thing about this one would be the lift, but its done wrong so I look at it as being less value than a stock one that nobody has messed up. Up to you ultimately, but if he's got that lift you should at least plan on having to replace the CV's he's running since they are probably being abused. look up aftermarket CV's on this site and see what you find lol.
id look for one that hasnt been messed with and just do your own 2 inch. even buying the lifts its pretty cheap for the 2 inch.
#10
Posted 05 January 2013 - 07:12 PM
just so that its said, going over 2 inches makes a ton more work. drop the crossmember, trans, and rear. linkages, steering extensions, possibly hoses.
just so there is no misunderstanding, the OP is on the east end of the country, 90s loyales are not a common item by a long shot over here.
