Oil Pan Removal on Brat???
19 replies to this topic
#1 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 07 January 2013 - 12:08 AM
How in the hill sam do you get all the rear pan bolts off without pulling the engine? Maybe.....no, I am just not seeing how one gets to the bolts at the back of the pan:banghead:
I'm sure it will be clear as day when one of you points this out to this unknowledged idiot here:-p
Any way HELP..
#2 Idasho
Idasho
    Garage Junky
  • 856 posts
  • North ID
Posted 07 January 2013 - 12:23 AM
Holes in the cross-member and a long philips screw-driver, thats how :-p
#3 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 07 January 2013 - 12:40 AM
Thanks
I must be partially blind or the holes are full of gunk and oil:eek:
#4 BEECHBM69
BEECHBM69
    USMB Regular
  • PipPipPip
  • 119 posts
  • Virginia Beach
Posted 07 January 2013 - 08:25 AM
Thanks
I had to take the motor mounts loose and jack the engine a little to get the angle right.
Good luck.
Dan
#5 Jessekrs123
Jessekrs123
    USMB Regular
  • PipPipPip
  • 117 posts
  • Oakville
Posted 07 January 2013 - 11:32 AM
Posted Image
I got mine off and on no problem, but there are two bolts on each side (one circled in the above picture) that you have to approach at an angle.
I'd use RTV or something to seal the new pan on, the factory cork gasket was hardly accurate and took a lot of fiddling to get it to fit right.
#6 presslab
presslab
    Subaru Nut
  • 632 posts
  • N. California
Posted 07 January 2013 - 11:36 AM
I love Loctite 518 for lots of stuff, including oil pans.
#7 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 07 January 2013 - 02:18 PM
How badly would it be to drill holes in the support to access those screws? Like say just a little bigger than the diameter of the driver. :brow:
#8 Idasho
Idasho
    Garage Junky
  • 856 posts
  • North ID
Posted 07 January 2013 - 02:32 PM
look closer.
Unless your brat happens to not have them, the engine cross member should have access holes.
For example:
Posted Image
See those 5 small holes? Thats them.
#9 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,796 posts
  • Denver, Colorado
Posted 08 January 2013 - 01:51 AM
1/4" drive wobble socket and long extension with the engine mounts undone and the engine about 1.5" out of the mounts. Did 3 in a day on various Subaru's but that was with a lift. Another shop used inferior silicone and outsourced warranty repairs to my shop. Ultra Grey from Permatex or Red Fuji Bond from Subaru-seems to be a permanent fix. I ditch the cork gaskets on the ea81s for these.
#10 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 08 January 2013 - 01:35 PM
Good to know that will be what I do if this doesn't hold, got it back on last night, I just need to go back & torque the bolts down to the setting.
I hope I didn't screw myself by not torquing them down last night.
I used the Permatex Copper spray gasket stuff.
#11 Idasho
Idasho
    Garage Junky
  • 856 posts
  • North ID
Posted 08 January 2013 - 02:16 PM
by far the best Ive used is Toyota Black RTV. It does cost $25 per tube though.
Not even a hint of a weep after 2k miles
Posted Image
#12 Brat78
Brat78
    USMB Regular
  • PipPipPip
  • 110 posts
  • Richmond Hill, GA
Posted 08 January 2013 - 02:46 PM
That is a PITA job with the engine in but it is possible. Hilariously I put my junkyard shelf motor in and then realized I had a really leaky pan. A week earlier the motor was sitting in the bed of the brat. How easy it would have been then.
#13 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 08 January 2013 - 03:01 PM
Posted Image
Holy COW that is a clean underside of a Subaru:eek::eek:!!!! That looks like it came off of the showroom FLOOR, of course almost anything would be better than what I have been looking at the past 2 nights!:lol::lol:
#14 Idasho
Idasho
    Garage Junky
  • 856 posts
  • North ID
Posted 08 January 2013 - 03:22 PM
It shoud be clean, that's the result of a zero mile rebuild ;)
I expect it to stay relatively clean, but it is still a Subaru :D
Still, with 2k miles on it now, not even a hint of a leak, anywhere.
#15 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 08 January 2013 - 04:58 PM
Reguardless, after 2000K that is wonderfull, IT is like a :Flame: or smokin HOTbabe on the beach:grin:
#16 presslab
presslab
    Subaru Nut
  • 632 posts
  • N. California
Posted 08 January 2013 - 05:20 PM
I have used RTV on pans before and it seals great... But it bends the poo out of the pan trying to remove it, even with trying to cut all the spots I could get to. Recently I pulled off a pan sealed with 518 and it came off a lot easier.
#17 Idasho
Idasho
    Garage Junky
  • 856 posts
  • North ID
Posted 08 January 2013 - 08:26 PM
You are doing it all wrong if you are concerned about REMOVING the oil pan when installing it. ;)
#18 Idasho
Idasho
    Garage Junky
  • 856 posts
  • North ID
Posted 08 January 2013 - 08:28 PM
Thanks.
If youd like to see more check out my thread in members rides
Lots of fun pics of a super clean '84 GL
http://www.ultimates...ad.php?t=135361
#19 bendecker
bendecker
    USMB is life!
  • 188 posts
  • Lakeside, CA
Posted 08 January 2013 - 10:16 PM
How bad would it be to drill holes in the support to access those screws? Like say just a little bigger than the diameter of the driver. :brow:
I don't know how bad it would be, but I did it a few years back and have had no problems.
I used a dremel tool. It took longer than I originally thought, but worked. Even with the bigger holes, it was still a beast to get a couple of the bolts back in. No leaks yet!
#20 Dinky26
Dinky26
    USMB Regular
  • Gold Subscribers
  • 128 posts
  • Wichita KS
Posted 09 January 2013 - 12:03 AM
I figured out where the holes were that lined up with the pan bolts..duh:clap:
I think one of the PO made said holes just big enough to get a 10mm socket through:headbang:, such a wonderful thing YAHOO!!! All the bolts actually were in pretty decent line too:clap:
Got here all back together though and GTG for now, still need to do the valve covers though.
