Ignition Problems
6 replies to this topic
#1 La FlammaBlanca
La FlammaBlanca
    New User
  • Pip
  • 3 posts
  • ashland, or Murka
Posted 07 January 2013 - 03:19 AM
First time poster here and I've searched the threads already posted on this subject so sorry if I missed the answer.
Here's the scoop: 1993 Subaru Legacy "La Flamma Blanca "
She stalled out while driving through some snow the other day. Uncharacteristic of the car. I've had it for about 10,000 miles and haven't had any problems. She just turned 202,000.
I checked the basics: Fuel, air, and spark. NO spark at the plug, but the Diamond F-569 coil was getting power, so I bought a new coil. Wasn't the problem. So now I'm wondering if this is going to be a phantom electrical issue I'll have to chase around for weeks and hundreds of dollars or if its just the cam pos switch?
Cougar? Bueller?
Any help in this matter is greatly appreciated!
Happy soobin
Oh and by the by I tried checking to see if it would throw a code with the self diagnostic computer but unfortunately the engine has to be running first:slobber:
#2 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 07 January 2013 - 10:56 AM
two things check timing belt then check the plugs on crank senser and posibbly crank senser
#3 La FlammaBlanca
La FlammaBlanca
    New User
  • Pip
  • 3 posts
  • ashland, or Murka
Posted 23 January 2013 - 03:12 PM
The timing belt was definitely bad. Replaced that. But now the belt is jumping teeth/something seizing up...
#4 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 23 January 2013 - 03:25 PM
Can you turn each of the cam shaft cog wheels by hand?
#5 La FlammaBlanca
La FlammaBlanca
    New User
  • Pip
  • 3 posts
  • ashland, or Murka
Posted 24 January 2013 - 04:49 PM
Each of the cogs turn and work with belt on as well. It's when the starter is engaged that it causes the belt to skip 15 teeth.
#6 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 24 January 2013 - 07:05 PM
Perhaps the tensioner is causing the problem. I would try putting on a new belt and turn the engine over by hand to see if that shows up the trouble. Removing the plugs will make it easier to turn the engine over.
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 24 January 2013 - 07:06 PM
I second this
