How in the world do you get a rear axle off the diff??
9 replies to this topic
#1 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 11 April 2004 - 02:32 PM
Trying to pull a rear axle among other things today. The outer end of the axle is loose and hanging, and the inner end is still attached to the diff. The pin is out, and I've pounded and pried on it for hours, and it hasn't moved a MILLIMETER. Can someone tell me, HOW DO I GET THIS THING OFF!!??
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,694 posts
  • Portland
Posted 11 April 2004 - 02:59 PM
Rust welded on. IF you do get it off, use some anti-seize on the splines when you put it back.
Heat with an acetelene torch, and then dunk it cold water - that might break it loose.
Dissasemble the joint, and knock the plug out of the bottom of the cup, then you can get to the stub bolt on the diff, and remove the whole stub.... You need the special stub bolt tool tho....
Last resort - cut it off with a die grinder.
#3 Hondasucks
Hondasucks
    Subaru Technician
  • 4,760 posts
  • Vancouver, WA
Posted 11 April 2004 - 03:20 PM
1/4 inch drive 6 point deep well 8mm Craftsman sockets work for gettting the bolts out, provided they are not stripped off (DO NOT try a 12 point socket, must be a 6 point and you gotta lightly smack it with a mallet to get it on all the way) but it will work, I have done it.
The special tool is an inverted torx, but you need one that will fit inside teh hole in the shaft, which most that I have seen do not.. Dunno where the tool could be aquired aside from a Subaru dealer. Maybe some deep creep, or other penetrating oil would help???
#4 GeneralDisorder
GeneralDisorder
  • 21,694 posts
  • Portland
Posted 11 April 2004 - 03:24 PM
The snap-on tool works - do a search on the board, it's on here somewhere.
#5 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 11 April 2004 - 04:13 PM
use the torch to get it real hot then pound on it as soon as you get the torch off. The heat will cause the outer part to expand more than the inner breaking the rust bond. I had to do this on my outers, and my surrounding seals survived the heat. You just gotta be careful about where you put the heat. I pointed the heat directly where the stub goes in.
#6 tailgatewagon
tailgatewagon
    1000+ Super USER!
  • 1,058 posts
  • Bozeman, MT
Posted 11 April 2004 - 08:22 PM
had a friend with this problem.
we tried
torch and then beas wax. = nothing
soaking in penitrating oil over night = nothing
took it to a machine shop and had them use a big press on it. = broken $200 pickle fork on press and not a bit of movement.
hope it works out for you
#7 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 11 April 2004 - 11:25 PM
my splines were really rusted to sh** and my method worked first try. The trick is to not bothering with wax or anything, just get on it with a hammer right away. before it has time to cool or for the heat to equalize between the two parts.
#8 The Scooby
The Scooby
    EJ Swap Junkie
  • 1,752 posts
  • South Seattle
Posted 12 April 2004 - 01:19 AM
yep, heat it up then put soem candle wax on it, the wax will penitrate it and act as a lube to make it come out, ive done this many times with the oxy-acidaline on engine bolts on chevy engines and many other things.
good luck,
Shean
#9 toybuilder
toybuilder
    Subaru Fanatic!
  • 458 posts
  • Longmont
Posted 12 April 2004 - 08:48 AM
Look at this old thread for some ideas.
http://www.ultimates...read.php?t=6850
#10 TROGDOR!
TROGDOR!
    Pastor of Muppets
  • 2,106 posts
  • Morgantown, WV
Posted 12 April 2004 - 05:14 PM
Since the shaft and inner joint are good, I just decided to get an outer joint and cup from work and put it on there. Since I'm working on a VERY tight time frame this seemed to be the way to go.
