lmdew Posted January 20, 2013 Share Posted January 20, 2013 I picked up a 2002 2.5 Subaru Legacy with a hole in the block. Helps to keep oil in the engine I had a 2000 2.5 engine from the yard. I installed it today and it did not start, a quick look at the crank gear confirmed they were different. The 2000 had the old style and the 2002 had the new style with numerous teeth. I swapped the crank and Drivers side gears (Thanks Shawn) and it did fire up but it's missing. I need to double check the timing as it was getting dark and cold. But other than the timing is there anything else that needs to be changed? The 2000 does have the additional airbox sensor and vent hose. I was just going to pick up the matching air box. Thanks Larry Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted January 20, 2013 Share Posted January 20, 2013 the '00 does not have EGR, does the '02? that probably wouldn't make it miss though. i would probably use the original intake. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted January 21, 2013 Share Posted January 21, 2013 I would stick with the 02 manifold as John suggested. Try the rubber hose EGR trick to keep the CEL away if the 00 head doesn't have the EGR port. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 21, 2013 Share Posted January 21, 2013 agreed - keep the intake with the vehicle if you can. missing - any check engine lights? plugs/wires/coil pack? there's one early SOHC EJ25 issue where there's a different timing belt depending if it's from a Forester or Legacy around 2000...if your 2000 is from a Forester you might look into that. Davebugs has attempted to explain that in depth on here in a post, might want to find that if you think it's worth your time. Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 21, 2013 Author Share Posted January 21, 2013 Thanks, the engine was from a 2000 Legacy into 2002 Legacy. I'll double check the timing and swap the original manifold onto it. Thanks, Larry Quote Link to comment Share on other sites More sharing options...
davebugs Posted January 21, 2013 Share Posted January 21, 2013 there's one early SOHC EJ25 issue where there's a different timing belt depending if it's from a Forester or Legacy around 2000...if your 2000 is from a Forester you might look into that. Davebugs has attempted to explain that in depth on here in a post, might want to find that if you think it's worth your time. YES!! SHort version (you can search my memory literally isn't what it was). After 2 bad 99 Forester SOHC's IIR I had them bring me a 2000 Legacy SOHC, then another 2002 Legacy 2.5 SOHC. Worst trouble I ever had with a car. Now I forget but I think it was between the 200 and 2002 Legacy (but possible between the 99 Forester SOHC and either of the Legacy engines the belt I purchased for the first 99 Forester replacement engine was too short. I thought I was loosing my mind when I did the usual tricks and couldn't get it on. A quick look and couldn't figure out why I needed a longer belt - all looked the same to naked eye. Called the parts store and the 2 engines did call for a different Dayco belt. Other than the timing belt issue swapping the intake which I had planned on and I did the HG's anyways and resealed the engine as usual. But the belt was a real head scratcher until I figured it out. Quote Link to comment Share on other sites More sharing options...
1197sts Posted January 22, 2013 Share Posted January 22, 2013 I am not sure about your situation, but I have experienced similar troubles with mixing and matching forester vs legacy engines, the difference in that case was the cam pulleys, resulting in the need for a different timing belt. (This is assuming the intake is ok). The pulley has a slightly different diameter/number of teeth, if I remember right it is the drivers side pulley. The black plastic gear from the forester is definitely different from the legacy, not sure about the other models. There are also little protrusions cast into the back of this pulley for timing, these can be different as well. I think if you swap all of your timing pulleys and gears from the original engine to the new you are ok, anyone else know if that is correct? You have to be careful because it can result in a one of a kind configuration if you do it this way. Quote Link to comment Share on other sites More sharing options...
davebugs Posted January 22, 2013 Share Posted January 22, 2013 I got correct belt. Thought that was safer than changing cam sprockets, etc. where I might have a sensor pickup issue and have to fight those battles. Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 22, 2013 Author Share Posted January 22, 2013 The crank and drivers side cam gear were swapped over. Old vs new style, totally different. Thanks Shawn for the heads up. As soon as I get back I'll be able to continue. Hopefully have an update on Sat. Larry Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 26, 2013 Author Share Posted January 26, 2013 Crank gear was off 1 tooth. Runs much better, still have to swap the intake. Quote Link to comment Share on other sites More sharing options...
lmdew Posted January 27, 2013 Author Share Posted January 27, 2013 Runs great with the correct intake. Thanks for the help. Larry Quote Link to comment Share on other sites More sharing options...
