Odd ABS question
8 replies to this topic
#1 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 20 January 2013 - 06:40 AM
Now I tested the right rear sensor and it's pretty much dead.. But at times I can drive maybe 1-16 miles without the ABS light on I can stomp on the pedel and have the ABS kick in.
So if the right rear sensor is dead (tested it multiple times with meter) why does it allow the ABS to work for however long it wants to then notices the sensor is gone?
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,966 posts
  • Charlottesburg, VA
Posted 20 January 2013 - 01:09 PM
How do you figure it's dead?
I guess you've checked the codes already to know its seeing a fault in the RR sensor?
#3 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 20 January 2013 - 06:25 PM
I checked with my ohm meter and I pulled the code. I checked the Left and it was in spec with the manual and the right had no reading at all.
#4 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 20 January 2013 - 06:55 PM
What does it physically look like? is it eroded?
#5 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 20 January 2013 - 06:57 PM
Not really.. must be bad internally.. looks like all the other sensors. I was just going to buy a replacement for $125 unless I can be sure one fits the plugs of a 97 Outback.
my thing is how can a sensor show open but the ABS works from 0-16 miles? Then I guess checks the sensor sees that it's bad then turns on the light?
#6 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,966 posts
Posted 20 January 2013 - 07:18 PM
What code did you get?
Did you wiggle the wire around while checking the resistance? Could just be an internally broken wire. Takes 16 miles for it to move just the right way before it breaks the signal. You could also test it by connecting a voltmeter set to AC and spin the wheel.
$125 is a waste of money for a sensor. They all work the same way, just find one in a junkyard that looks the same and has the same plug.
#7 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 20 January 2013 - 07:43 PM
I got the code for the right rear sensor that's the only code in the system..
I tried looking on ebay but got little hits or the plug does not match up. It's not always 16 miles, sometimes it only takes a few wheel rotations.. very random.
#8 nipper
nipper
  • 18,193 posts
  • Long Island NY
Posted 20 January 2013 - 08:59 PM
How is your tone ring?
#9 1-3-2-4
1-3-2-4
    Subaru Mike!
  • 3,792 posts
  • Greenwich
Posted 20 January 2013 - 09:00 PM
perfectly fine
