Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Pulling EJ22, Can't remove Flex Plate bolts...
Started by
suprunner
, Jan 20 2013 06:24 PM
11 replies to this topic
#1
Posted 20 January 2013 - 06:24 PM
I've done everything necessary to pull the EJ, except that I can't undo the torque converter (TC)/ Flex Plate bolts. I've tried multiple tools and entry options... Even tried going under the intake manifold (removed oil pump). Will I have to take the Intake Manifold Completely off?? Every time that I get a socket/wrench on, then put any torque on it, it just pops off or rounds a point on the head. . Can I remove the engine with the TC/Flex Plate still attached? I don't have any use for the TC, so I'm not worried about destroying it... The motor will be going into a M/T Loyale.
Thanks,
Greg
Thanks,
Greg
#2
Posted 20 January 2013 - 06:35 PM
6 point 12 mm socket on the 1/4" ratchet. Put a 14mm wrench on the ratchet handle to give you some leverage.
Yes you can pull the TC with the engine. it's tight but it will come out.
Larry
Larry
#3
Posted 20 January 2013 - 07:45 PM
remove the intake manifold and use 1/4 socket and extension laid across the top of the block.
3/8s stuff may work, but with the intake out of the way it is a no brainer.
i resisted this technique for too long, but it is the easiest way.
#4
Posted 20 January 2013 - 07:59 PM
I use a 12mm socket on the end of a serpentine belt tool. Just enough room and plenty of torque from the 18" handle.
A 1/4" drive ratchet works as well. Most you can fit the handle of a small floor jack over the handle of the ratchet for extra torque.
#5
Posted 21 January 2013 - 12:03 AM
a deep offset wrench will also work, without removing manifold
O.
O.
#6
Posted 21 January 2013 - 12:13 AM
when i pulled mine i had a hard time too. i was planning on using it for a swap as well so i removed the motor with the tc/flexplate on. then i cut up the flexplate and took that byatch off:grin:
#7
Posted 21 January 2013 - 12:14 AM
oh ya, we had also removed the core support for another project so that was kinda easier than going straight up/out i think
#8
Posted 21 January 2013 - 01:43 AM
I posted this in your other thread (Which I moved to the Retrofit forum).
Theres only 4 bolts and you can access them from the hole on top of the bell housing. Its to the left as you look at the engine and may have a black rubber cover on it. I use a 12mm socket (make sure its a good 6pt one) and a 3/8 ratchet. It can be a pain to break them loose sometimes. What I have done is smack the handle of the ratchet with my hand or use a soft blow hammer.
#9
Posted 21 January 2013 - 02:52 AM
6 point socket and a proper wrench/extension/pipe that gives you enough leverage to put some force on it...all the while, keeping the socket fully seated on the bolt head. i've never had that method fail. friend was helping me once and rounded a bolt head off when using a 12 point socket...that's a no-no on those bolts.
i've pulled motors with the torque converter attached, it can be done.
though if you don't need the flexplate i wonder if there's enough room to get in there and cut it off around the bolts.
#11
Posted 22 January 2013 - 06:23 PM
I've always loosened the I/M and jimmied enough room to get my 3/8" extensions through. Goes under the fuel hard lines and over the coolant x-over pipe.
#12
Posted 23 January 2013 - 03:08 PM
Thanks for all that have replied.
I ended up removing the Intake Manifold (IM) (which I will probably do in the future), getting two of the bolts off the plate, and then completely rounding off the remaining two.
Bought a Dremel, and cut those babies off.
The two bottom nuts for the bell housing were my next nightmare. I couldn't get a good angle on them for the life of me. But I kept my cool and got them off.
Again, thanks for all the help!
Greg
Greg
