Sudden Electrical Outage
4 replies to this topic
#1 JCarp
JCarp
    New User
  • Pip
  • 4 posts
  • Gunnison, CO
Posted 21 January 2013 - 06:40 PM
As I was driving home from work last night, all the lights on my 1980 GL 1600 went out. Only the hazards/turn signals continued working. The fuses are all fine in the box but the (15A) headlight ones are not receiving any power (tested via electrical pen). However, when I use the pen to arc from a working fuse to those ones, the headlights work. What should I look for next?
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 21 January 2013 - 06:54 PM
Take a look at the fusible links on the strut tower in the little black box. the black one is the main. There should be a red and a green one, also.
The headlights ground thru the switch.
#3 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 23 January 2013 - 10:13 AM
I agree with MilesFox. The fusible link connections are a common place to have bad connections that can cause this kind of trouble. While your checking that it may be a good idea to also clean the battery connections since that is another common place for problems that a lot of people neglect to keep clean.
#4 JCarp
JCarp
    New User
  • Pip
  • 4 posts
  • Gunnison, CO
Posted 23 January 2013 - 03:50 PM
Thank you all for the help it worked out perfectly!
#5 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 23 January 2013 - 05:39 PM
You're welcome for the help. Thanks for the update and glad you got it fixed.
