Pure Carnage!!
14 replies to this topic
#1 Adam N.D.J.
Adam N.D.J.
    Quite Rusty, but working.
  • 3,290 posts
  • Medford, Oregon
Posted 11 April 2004 - 10:36 PM
Well, the Rogue Roo's went out wheeling today. Had a good ol time. But the Brat went down. It still has a problem keeping the struts in the knuckles. This turned out to be a serious downfall. I'm crawlin up a hill, off camber, big ditch. The passenger side knuckle comes off the strut and drops down. No problems while the tire is hanging, but as soon as the tire touched the ground, rotating force of over 150 LBs of torque multiplied by 60 times is thrown into that hanging knuckle and tire assemble, the tiny ball joint on the bottom of the knuckle of course couldn't handle almost 10,000 pounds of force being applied to it, and snapped, flipping the knuckle upside down, and bending the tierod. I've got video of whot it looked like, and there will be pictures up soon. Quite impressive!! Was definatly something else to see the caliper on the front!! Had to wait for parts, did a lot of sittin today, but all in all, it was a good day wheelin.
#2 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 11 April 2004 - 10:47 PM
Ouch!! Are the bolts for the strut/knuckle threaded all the way to the bolt head or just part way? Reason I ask is that I've seen the wrong bolt(ball joint bolt) installed in the knuckle. It tightens down but doesn't get tight enough to hold the knuckle to the strut.
#3 Adam N.D.J.
Adam N.D.J.
  • 3,290 posts
  • Medford, Oregon
Posted 11 April 2004 - 11:32 PM
Oh yeah, it's the right bolt. And the "clamp" of the knuckle is all the way down, the metal is touching. My Brat is just telling me that it doesn't like struts, have to admit, neither do I. Hmm, back to the drawing board.
#4 subarubrat
subarubrat
    1000+ Super USER!
  • 1,469 posts
  • Bealeton, VA
Posted 11 April 2004 - 11:36 PM
I got a grade8 and lockwasher and so far no problems. I am thinking about welding a stronger tab though.
#5 ru4x4ever
ru4x4ever
    Eat, Live, Breath Subaru
  • 349 posts
  • Medford, Oregon
Posted 12 April 2004 - 11:14 AM
But damn we had a great time :headbang:
-Sean
#6 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 12 April 2004 - 11:23 AM
Yup! My gold wagon did real good for no lift, and no welded dif! Will be fixing all that soon enough :brow:
#7 oddcomp
oddcomp
    Subaru Master
  • 1,763 posts
  • longview ,wa
Posted 12 April 2004 - 11:29 AM
try limiting straps
to keep the suspension from drooping down that far...
just a idea
#8 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 12 April 2004 - 11:59 AM
Yeah, he put some on as a trail fix ;) But he will have permenatn fix for it very soon :brow:
#9 Subadoom
Subadoom
    Silent Bob
  • PipPipPip
  • 48 posts
  • Central Point
Posted 12 April 2004 - 01:18 PM
heres what i got before by batteries died.
#10 Nug
Nug
    Lurker/off-topic poster
  • 1,968 posts
  • West Point, VA
Posted 12 April 2004 - 03:32 PM
As long as you are breaking stuff, at least go all the way!
#11 bakerman1
bakerman1
    USMB Regular
  • 128 posts
  • Ashland
Posted 12 April 2004 - 07:49 PM
Bummed I missed the good time. I was busy with Easter stuff. Next time hopefully I will be able to meet some of you guys and hit the trails. I have my wheels and tires, just need to lift it. Looks like a trail run with some good stories :-) I'm sure Adam will come up with a good fix.
Ken
#12 Adam N.D.J.
Adam N.D.J.
  • 3,290 posts
  • Medford, Oregon
Posted 12 April 2004 - 07:57 PM
Two words:
MULE TAPE!!
#13 subaruloverbrad
subaruloverbrad
  • 268 posts
  • ABINGDON
Posted 12 April 2004 - 08:00 PM
have you welded an extension onto the strut? I started to do that but decided to use a spacer instead on top of the strut...... one thought would be to take a die grinder and make slot just a little bit wider on the un threaded side, then it might clamp tighter. if you made the slot wide enough, you might be able to weld a tab on the strut tube that sticks through the slot with a hole drilled and clamp bolt through the hole and tighten.? i would probably try the later of the two. not that any of my ideas would ever work :(
#14 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 12 April 2004 - 08:28 PM
Nice! Looks like art!
#15 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 13 April 2004 - 03:21 PM
Did your brat come with a front sway bar? They kinda work like OEM limiting straps :)
If you wanna keep the travel gained w/o a sway bar might wanna look into the above idea of limiting straps on the control arms.
