Turbo Transmission Q
3 replies to this topic
#1 Responsible Jon
Responsible Jon
    USMB Regular
  • PipPipPip
  • 47 posts
  • Indiana
Posted 25 January 2013 - 01:34 PM
I got an 88 GL10 Turbo wagon with 5mt and locking center differential. Using the information on gears found here, calculated my stock gearing and the gearing for this 5 speed.
.871*3.7= 3.2227 -Turbo gearing
.855*3.9=3.4515 -stock 82 gearing
So putting this transmission into my 82 Brat would decrease my RPMs to go the same speed in top gear, correct?
I know it the turbo has 25 spline stubs, can the shafts be swapped out to the 23 spline stubs from my 4 speed?
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 25 January 2013 - 01:41 PM
No. You can't swap stubs on MT's without splitting them open and I am not entirely sure that 4 speed stubs would work. 5MT stubs (right up through EJ stuff) would definitely work. You can build custom axles but unless you want to spend a lot of time at the junk yard trying to piece things together you will need to buy 4 axles from one of the "new" axle manufacturers like EMPI and swap the inner joints around. Factory axles use too many joint/shaft sizes and most cars of that vintage have such a mish-mash of axles in them that there's no telling what will fit - thus the easiest way is to buy 4 new axles - 2 EA81 and 2 Impreza and swap the inner joints.
#3 Gloyale
Gloyale
    It's a sickness
  • 7,091 posts
  • Corvallis, OR PNW
Posted 26 January 2013 - 12:41 PM
your #'s are off just a tad.
Here you go
5spd turbo FT4wd= .871 x 3.7 = 3.2227
82 4spd D/R 4wd= .885 x 3.9 = 3.4515
And for comparison
5spd N/A 5mt S/R or D/R 4wd= .781 x 3.9 = 3.0459
So actually you would get better top end gearing out of a Stock EA82 5spd, single or dual range. And they have 23spline stubs so no probs with axles in your brat. You won't have the FT4wd:-\
FWIW, you can put 23 spline stubs into a Turbo 5spd, but you will have to split the case.
#4 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,809 posts
  • Denver, Colorado
Posted 28 January 2013 - 02:56 PM
Ive swapped the stubs and would do it again in a heartbeat if it was an EA81 car. Not needing a custom axle is enough for me and I share space with my friend and axle rebuilder Marshall Wolf who is known around here as MWE (Now FW Enterprises). Being able to replace one when I am away from home is the big thing.
