Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
1996 Legacy does nothing when hitting the gas. Think I killed it?
#1
Posted 30 January 2013 - 04:52 PM
1996 Subaru Legacy. Standard engine with automatic transmission.
The Problem (s):
Last week, upon start-up early in the morning (it was very cold here is southern oregon), the car did something really weird for my girlfriend. Here's the text I got from her:
"I started her up, she was fine. Put her in reverse, still fine. Hit the gas, nothing. Wouldn't accelerate or even sound like she wanted to. The engine didn't rev at all. All the lights on the dash came on like she was throwing a fit. Turned her off and restarted her, and everything worked fine."
Something else that's likely related:
The check engine light came on a few days earlier (see details below) and when I hook up my ScanGauge II to the computer, it reports "No Error Codes Found." Also strange is that when the ScanGauge is hooked up while driving, it seems to get intermittent feedback from the computer. At times the values just freeze. At other times the gauge seems to shut down because it's not getting any signal.
I hooked the gauge up to my Toyota RAV4 (2008) and it registers and displays real-time values perfectly, without the intermittent display issues seen on the Subaru.
The check engine light was on for about 5 days. During that time the car's idle was rough/low, the transmission seemed to shift at higher than normal RPMs (automatic), and all-around performance seemed a little rough. But one morning the light didn't come on, and the car has been running much better. Possibly an intermittent ground somewhere?
Background:
The water pump seized a few weeks ago when she was driving it home from a ski trip. The car overheated, all the coolant drained out, and she drove it for maybe a minute or two after the temperature gauge dropped (from no coolant) before pulling over and turning it off.
Since I had to disassemble the timing belt & idlers to change the water pump, I replaced them at the same time.
When I did the repair, I removed the radiator, which meant disconnecting the transmission cooling lines. When I put it back together I had to top off the transmission level.
A day or two after I topped off the transmission fluid, a check engine light came on. I hooked up my ScanGauge II but it gave no failure code.
Any idea why it threw that fit the other morning? Please don't say the computer is dying!
Just thought I'd ask in case it's a well-known failure / trouble indicator.
Thanks,
Tim
#2
Posted 30 January 2013 - 05:10 PM
if it is the computer, which is very rare in a Subaru...really rare...they are super cheap and easy to replace. just get a used one, they don't fail enough to warrant new prices.
#3
Posted 30 January 2013 - 05:15 PM
i'd check to see if the throttle is moving properly with the gas pedal. it probably is but with the "hitting the gas - no response" - issue i'd like to verify.
grossgary - thanks for the quick reply.
Forgot to mention that I checked the throttle linkage, and all was well.
Nice to know the computers are reliable - and cheap. That's a relief.
Tim
#4
Posted 30 January 2013 - 05:45 PM
You can email me: cal_look_zero@yahoo.com
#5
Posted 30 January 2013 - 11:57 PM
Check the battery cables and grounds on the engine and chassis.
Possible the terminals in the diagnostic connector are dirty or loose causing connection issues. Could be a poor connection at the ECU as well.
#6
Posted 31 January 2013 - 09:54 PM
Scangauges are great tools, but sometimes a CEL will be thrown and the gauge will freeze up. I have had this happen to me, and I don't remember the resoning for it, but it has something to do with the problem being intermitent at the time so the computer can't lock into a code, or something like that.
#7
Posted 31 January 2013 - 09:59 PM
