1 Prong vs 2 Prong Coolant Temp Sensor
8 replies to this topic
#1 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,997 posts
  • West Des Moines, IA
Posted 10 February 2013 - 11:05 AM
So i have a 1988 subaru that recently had a ea81 swap with a weber setup.  Everything works fine except the temp gauge.  I picked up another coolant temp sensor to see if that might work but its a 1 prong and the one in the manifold is 2 prong.  Im not sure the year of the manifold but i think its 85.  I have a 87 Factory Service Manual and the manofold in the car for SPFI and Carb are not the one that is on the car.
1.  Am i missing another sensor somewhere.  The 2 prong is right next to the T-Stat housing.
2.  Could i use the 1 prong anyway with the 2 prong connector.
3.  I thought the 2 prong was for the computer and there was a 1 prong somewhere that just did the gauge.
#2 MilesFox
MilesFox
    Catch this Fox!
  • 10,685 posts
  • Madison/Milwaukee, WI
Posted 10 February 2013 - 01:33 PM
look for another hole. the single spade terminal is more underneath the thermo housing.
#3 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 February 2013 - 01:36 PM
Edit:  This information may be unrelated/invalid.  I had "forgotten" that the XT is MPFI, not SPFI. :endEdit
The 88 XT FSM shows the 2-prong sensor used for guage and "ECM".  The spade connectors are arrayed in a "T"-shape, with the top of the T being for the guage.
Edited by NorthWet, 10 February 2013 - 04:19 PM.
#4 The Dude Abides
The Dude Abides
  • 2,997 posts
Posted 10 February 2013 - 03:30 PM
So in theory i should be able to use the 1 spade connector adn just hook that side up to the gauge.    And i looked, there isnt another hole, or any other types of wires coming out of that area.
#5 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 February 2013 - 04:04 PM
I would listen to Miles before I listened to myself this morning (my brain is not all there yet).  That being said...
You can test out your wiring and gauge by grounding the connector's terminal for the gauge.  (Top of the "T" in my XT manual.)  IF this is the right connector, and IF the wiring and gauge work, then the gauge should indicate maximum reading.
Edit:  Is the wiring harness from the EA82 chassis or the Ea81 engine?
Edited by NorthWet, 10 February 2013 - 04:06 PM.
#6 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 February 2013 - 04:17 PM
My information may be totally INVALID.  The XT is MPFI, not SPFI, so engine wiring may be different.
I looked at an 89 SPFI GL, but it looks like it has a different style of sensor/connector.
#7 The Dude Abides
The Dude Abides
  • 2,997 posts
Posted 10 February 2013 - 05:17 PM
Its an ea82 carb wireing going into ea82 spfi
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 10 February 2013 - 05:43 PM
My apologies.  Original post referred to an EA81 swap.
Edited by NorthWet, 10 February 2013 - 05:43 PM.
#9 The Dude Abides
The Dude Abides
  • 2,997 posts
Posted 10 February 2013 - 09:46 PM
It works though
