Guages and Stereo finally IN
10 replies to this topic
#1 Flow
Flow
    Eat, Live, Breath Subaru
  • 257 posts
  • Roy
Posted 12 April 2004 - 08:10 PM
Finally got everything the way I like it, and I only had to tear everything apart twice. :rolleyes: The Backing for the guages and switch is a rear cubby door I got from the J/Y, the one you can see in the bottom pic. Switch runs a relay that will eventually power driving lights. Need to upgrade the alt first. I got plans for tucking a bass amp in the other side as soon as I find one suitable, all the wiring is ran. Also need to do something for the heat the amps generate. Thinking about PC fans...
Posted Image
Posted Image
Posted Image
#2 Subi81
Subi81
    1000+ Super USER!
  • 1,009 posts
  • Ventura, Ca
Posted 12 April 2004 - 08:25 PM
That looks really good, Great idea about using the junk yard plastic door for the panel. Real Clean!! Like the switch too. How did you secure the switch? Screws, tape, glue.. Dam completely flawless! Congrats
#3 xtlover
xtlover
    USMB Regular
  • PipPipPip
  • 87 posts
  • Mount Vernon
Posted 12 April 2004 - 10:25 PM
I should pay you and have you install my amp and my cd player in my xt:D Interested? lol
#4 Flow
Flow
  • 257 posts
  • Roy
Posted 12 April 2004 - 10:38 PM
Thanks, the switch is the same type as the rear wiper switch on any ea-82. I basically cut the hole to be a friction fit. It pops in and out from the front. I think I'm gonna use it for fog lights. Someone on the board had the idea to wire driving lights up to the 4WD button on the shift knob of a singlerange tranny. On the Fly driving lights would be cool. If I can find a knob in blue...
Xt, Thanks but I was making up new cusswords with this install. I smoked the headlight switch trying to tie the guage lights in to the dimmer. Got that straight, only to have to chase a ticking noise that was getting radiated into my rca cables. Of course that was after I had put the whole interior back together. Word of advice: Take your time and be sure to test the stereo with the engine on before buttoning everything up. I got in a hurry and paid the price.:banghead:
#5 Qman
Qman
    Happiness is... no lag!!
  • Moderator
  • 11,119 posts
  • Sumner
Posted 12 April 2004 - 10:40 PM
Nice! Are you going to get adequate air flow for the amp in the rear cubby?
#6 Flow
Flow
  • 257 posts
  • Roy
Posted 12 April 2004 - 10:51 PM
It hasn't been a problem so far, the 4 channel amp isn't pushing a whole lot with the gains at mid level. I'm going to put in some small cpu fans to circulate the air but I think it will be more crucial for the bass amp.
#7 bushbasher
bushbasher
    exhaust fume addict
  • 1,707 posts
  • Sooke B.C. Canada
Posted 12 April 2004 - 11:21 PM
maybe just drill some holes in the ceiling and floor of the cubby hole and let convection do its thing.
#8 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,193 posts
  • WA
Posted 13 April 2004 - 02:40 AM
I think PC fans run at 5/6v, you might fry them at 12v. Lets see, will running them parellel drop the voltage? Been a long time since I did this stuff....
#9 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 13 April 2004 - 08:12 AM
That looks great!
The PC fans work well for amp cooling. They are 12v and can be mounted anywhere
#10 rallyruss
rallyruss
    Subaru Master
  • 1,653 posts
  • San Jose CA
Posted 13 April 2004 - 11:55 AM
running in parallel would not work for 6v fans on a 12v system but in series would work if the fans were the same amp draw and vlotage.
#11 nutt7
nutt7
    certified hoser!
  • 241 posts
  • Tempe
Posted 13 April 2004 - 05:23 PM
rallyruss is right...you could run the fans off the remote switch, so when the amp is on, the fans are on...if that amp is only running door speakers, I doubt heat will be an issue...I think a vent or two would be adequate, like bushbasher stated...the sub amp you should cool with fans...
I like where you put the distribution block! (I hope you have a main fuse by the battery) nice work everything looks clean! Good advice on taking your time! cant stress how important that is! I know we have all fried or broken something one time or another! :-p
