2000 Legacy Spring Compatibility
3 replies to this topic
#1 nickb21
nickb21
    Subaru Fanatic!
  • 566 posts
  • Hunterdon County
Posted 13 February 2013 - 11:30 AM
Hi All, I didn't get to do a lot of research before posting, forgive me. Scrambling to fix another problem.
Just found a busted spring on my friends 2000 Legacy L - wohoo. I called a few junkyards and it looks like this year/model doesn't really interchange with later years. I thought that most of the BE/BH springs are compatible from various suspension threads.
If I use the current top hats/struts, is there a reason why any 00-04 L/GT spring (left or right) won't fit properly?
Thanks a ton!
#2 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 13 February 2013 - 03:58 PM
typically you can find out what will fit by searching www.car-part.com. put in your zip and sort by distance. your search for a 00 legacy spring will return all that match / fit.
i'm pretty sure the legacy has a didfferent part number than the outback , the forester, or the baja.
for more info, you can search for your part at http://opposedforces.com/parts. this will give you part numbers, click on it and then on the usage info . you will see a list of the cars the uase that part.
i have a complete set of struts and springs off a 00 legacy wagon, with 85k miles if you are interested. i swapped in outback struts.
what broke, front or rear, left or right?
#3 nickb21
nickb21
    Subaru Fanatic!
  • 566 posts
  • Hunterdon County
Posted 13 February 2013 - 05:52 PM
Yea, looked through car-part, it seems to only want to list 2000 as compatible. Different part numbers on opposed forces in 2001 as well. Friend of mine at a dealer printed me out the part list - looks like 1999-2000 (Or 2001) will 'officially' interchange. Need to read it closer.
Front Passenger, bottom part of the coil.
I'm interested, send me a PM. I'll be back online late this eve, or in the morning.
#4 johnceggleston
johnceggleston
  • 6,712 posts
  • Virginia
Posted 13 February 2013 - 07:51 PM
http://www.ultimates...-outback-wagon/
where are you located??
