Uberoo Posted February 24, 2013 Share Posted February 24, 2013 So the rear recovery points on my 81 hatch more or less ripped out of the body. here is the driver side rear: Not to bad other than the loop has long been ripped out. here is the passenger side rear: As you can see it is completely destroyed. I cut out the driver's side section already and was shocked to find that the "recovery" points were nothing more than a single layer of thin sheetmetal in a box shape.The cargo floor itself isnt much better.I will cut out the passenger side after I drop the fuel tank,because when I was cutting the driver's side the underbody rust proofing caught on fire and I really dont want that sorta fire anywhere near the gas tank. Anyway have you guys ever reinforced that area?I was thinking 1/8" box channel welded to the floor above with some 1/8" angle iron welded to the sides to give it more surface area.I'm still a bit leary because all the the strength comes from the strength of a thin piece of steel in tension(the floor itself.If I did it like that it probably would be ok to get pulled out but dont do any pulling of my own,unless the vehicle in question is smaller than my car. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted February 24, 2013 Share Posted February 24, 2013 I would tie the rear bumper mount to the mustach bar mount and the other rear component mounts, those stock Tie down points were not designed for recovery, they allowed the car to be tied down during shipping Quote Link to comment Share on other sites More sharing options...
Idasho Posted February 25, 2013 Share Posted February 25, 2013 Yeah, those are never intended as recovery points. To get the most solid recovery points on the rear, it will need to be tied into the bumper mounts. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted February 25, 2013 Author Share Posted February 25, 2013 that was the bumper mount points.If you look at the passenger side pic you can see the bumper shock tweaked. Quote Link to comment Share on other sites More sharing options...
monstaru Posted February 25, 2013 Share Posted February 25, 2013 Never should have used them as such.OLD tech there..... Only thing to do is put box tube inside then weld captive nuts.Then tie into top of rear diff mount. SInce it is an offroader, just bolt through the top with backing plates as well. AND learn how to recover without jerking. cheers Quote Link to comment Share on other sites More sharing options...
Uberoo Posted February 26, 2013 Author Share Posted February 26, 2013 I try not to jerk,but when you ask others not to jerk you out they look at you like your from mars. Quote Link to comment Share on other sites More sharing options...
tron Posted February 26, 2013 Share Posted February 26, 2013 http://www.bubbarope.com/ is a pricy alterinitive to getting jerked. they make a smaller 7400 lb rope. Quote Link to comment Share on other sites More sharing options...
Uberoo Posted February 27, 2013 Author Share Posted February 27, 2013 The people I go wheeling with have enough sense not to jerk with a chain,But even with a snatch strap it still has to be hooked to something solid. Quote Link to comment Share on other sites More sharing options...
ferp420 Posted February 28, 2013 Share Posted February 28, 2013 sweet carnage Quote Link to comment Share on other sites More sharing options...
Numbchux Posted February 28, 2013 Share Posted February 28, 2013 This is how people die. I'll walk before anyone gets anywhere near my vehicles with a chain. The rear bumper on my Brat has 2" square tube (1/4" thick, IIRC) pounded easily 18" into the frame rails where the rear bumper mounts, and bolted with Grade 8 hardware in 4 or 5 places on each side. Then 2 pieces of tube welded onto that to tie it together. Then the ends of that square tube have holes drilled in them for a shackle and recovery strap to be attached. Here's an old picture, right after we finished building it: Quote Link to comment Share on other sites More sharing options...
