Going to open a new topic since my previous one started of as a question about security system and gradually made to different topics, and kind of off kilter from where it all started.
What I've got is 16 flashes of my automatic trans cooler light (97 impreza coupe AWD), It was pointed out that this is most likely due to I believe it was called the c duty silenoid. Which after doing some research, appears to be beyond my mechanical ability to change myself. So I checked with a local shop here in town and he said he had done one a couple months ago. And as a test to see if it was the silenoid or not, he put a fuse in the FWD fuse holder on the passenger side up against the fire wall. He described this as a way to disable that silenoid and basically make run just in FWD.
I did this, and you can still feel a binding when turning slowly on the pavement. So either thats not really whats supposed to happen when you put a fuse in their. Or I have a different problem is my guess. And yes it does still flash 16 times with the fuse in the FWD fuse holder.
Any thoughts?
