I have had no problems driving the car. Parked it in the garage last Friday. Monday morning, it won't start but it does turn over and cranks. I have checked the following things:
-- spark, good in #1 cyl. Didn't check the rest
-- fuel, appears to be getting fuel, didn't measure fuel pressure
-- timing belt- took of the end covers. Belt is intact and has good tension. Didn't check timing marks.
-- codes- only stored code is 32 o2 sensor
I did notice that the radiator fans run continuously when the key is on. Is this normal? I'm thinking about replacing the coolant temp sensor. Can the CTS fail in a way that would prevent the car from starting?
Edited by Sister7, 25 March 2013 - 12:57 AM.
