OBD1 EJ22 No code mystery
cam shaft ej22 obd1 legacy
14 replies to this topic
#1 NorthCoast
NorthCoast
    USMB is life!
  • 503 posts
  • Puyallup, WA
Posted 10 March 2013 - 08:01 PM
Engine starts and idles fine but bogs out and dies at 1500 RPM.
I pulled the timing belt covers off to check the timing marks on the cams and it "looks" like it's still right.  Swapped out the cam sensor to see if that was the problem but no change.
When idling the left cam pulley looks like it might be wobbling slightly but could be an optical illusion. I checked the pulley to see if there was any play but it was solid. Any ideas?
#2 mikaleda
mikaleda
    legacy specialtist
  • 2,263 posts
  • priest lake, Idaho
Posted 10 March 2013 - 08:10 PM
IMHO I would start by verifying that you have the correct fuel pressure.
Also if it has been a long time since you have changed the fuel filter that might be a good thing to do to.
#3 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,777 posts
  • Texas
Posted 10 March 2013 - 10:30 PM
does it run if you get above 1500rpm?
assuming good 'tune-up' parts and general condition, maybe a TPS problem.
#4 NorthCoast
NorthCoast
    USMB is life!
  • 503 posts
  • Puyallup, WA
Posted 11 March 2013 - 08:26 AM
Fuel filter was my first thought but no change after being replaced. TPS was recently gone through as well.
#5 1 Lucky Texan
1 Lucky Texan
  • 7,777 posts
  • Texas
Posted 11 March 2013 - 09:25 AM
did this begin slowly?
any work done immediately prior to the problem?
#6 NorthCoast
NorthCoast
    USMB is life!
  • 503 posts
  • Puyallup, WA
Posted 11 March 2013 - 09:33 AM
No work done prior and the onset was sudden.
#7 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 11 March 2013 - 10:12 AM
You might have a problem with the MAF sensor. Check the fuel pressure and make sure that is okay also. If those things are good then I would check the compression to see if there is a valve timing issue.
#8 1 Lucky Texan
1 Lucky Texan
  • 7,777 posts
  • Texas
Posted 11 March 2013 - 10:22 AM
kinda wondering about a possible clogged cat. conv. or other exhaust restriction.
vacuum gauge test might show that.
Edited by 1 Lucky Texan, 11 March 2013 - 10:23 AM.
#9 NorthCoast
NorthCoast
    USMB is life!
  • 503 posts
  • Puyallup, WA
Posted 11 March 2013 - 10:26 AM
Exhaust was just redone so no issues there.
#10 CoupedUpSubie
CoupedUpSubie
    USMB is life!
  • 160 posts
  • Woolwich
Posted 11 March 2013 - 02:06 PM
I would suggest pulling a couple spark plugs and looking to see if they are covered in fuel or not, also check the plug gap. Another piece of information is what plugs do you have in it? Some are known to cause problems.
Then go to your MAF and airfilter. Get a can of MAF sensor cleaner and clean the MAF sensor(even if you don't have a code, its still a good idea to do on occasion).
Also check fuel pressure as engine rpm is increased, pump might not be putting out enough fuel as the demand is increased.
#11 Gloyale
Gloyale
    It's a sickness
  • 10,544 posts
  • Corvallis, OR PNW
Posted 12 March 2013 - 10:00 AM
PVC or IAC tubes disconnected?
#12 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 12 March 2013 - 10:04 AM
+1 maf senser or feul preshure
#13 NorthCoast
NorthCoast
    USMB is life!
  • 503 posts
  • Puyallup, WA
Posted 17 March 2013 - 05:06 PM
Fuel pressure 32. Swapped MAF and ECU. No change. New plugs. No change. All vac and pressure lines attached. New timing belt. No change. The only thing I've found out of spec is IAC resistance. 10.5 instead of 9. Would this cause the issue or am I missing something.
#14 Gloyale
Gloyale
    It's a sickness
  • 10,544 posts
  • Corvallis, OR PNW
Posted 17 March 2013 - 06:14 PM
gotta be an unmetered air leak.
PCV hoses, and IAC tube double check for cracks maybe put clamps on them.
#15 NorthCoast
NorthCoast
    USMB is life!
  • 503 posts
  • Puyallup, WA
Posted 17 March 2013 - 07:37 PM
Negative. 1 Lucky Texan got it right. Clogged cat. I put my wheelin exhaust on because that was the only thing I hadn't tried and it loved it. So frustrating but at least I can go wheeling next weekend.
