2.2 to 1.8 swap. . . .
2.2 1.8 swap
5 replies to this topic
#1 Dazed Dreamer
Dazed Dreamer
    USMB is life!
  • 154 posts
  • Aurora, Colorado
Posted 13 March 2013 - 08:30 PM
I am working on a friends 1992 Subaru legacy and she was given a 1.8 motor from an impreza because her engine was blow, my question is can I just swap the engine harness and have everything be ok? will it run? will it run bad? will it pass Colorado State Emission Laws?
#2 Subruise
Subruise
    Official Party Pooper
  • 1,568 posts
  • pierce county
Posted 13 March 2013 - 08:39 PM
you need to use the search function. whether or not, and how well, depend on what years the two motors are from. if they are from the same gen, itll be plug and play. if not....well back to searching
#3 987687
987687
    Rally Suby!
  • 4,067 posts
  • Northern Maine
Posted 13 March 2013 - 09:13 PM
Put the 2.2L intake on the 1.8L engine and swap the knock sensor onto the 1.8L engine. Then it will directly bolt in.
#4 grossgary
grossgary
    Elite Master of the Subaru
  • 21,730 posts
  • Midatlantic
Posted 14 March 2013 - 06:17 AM
what he said, it's very easy.  no wiring swap.
remove the entire intake manifold with wiring off the EJ18.
install the EJ22 intake manifold (with new gaskets) onto the EJ18 engine - installing the knock sensor while you're at it.
done.
I'm assuming they both have EGR, i think EJ18's always do so you should be fine...
good time to just get a new knock sensor off ebay for $20, they fail fairly often.  i'd also be installing a new timing belt kit - $80 off ebay for all new belt, tensioner, pulleys.
#5 Gloyale
Gloyale
    It's a sickness
  • 9,822 posts
  • Corvallis, OR PNW
Posted 14 March 2013 - 10:56 AM
You will need to plug the egr port in the EJ18. Drivers side head in the back.
Other than that its drop in.
#6 grossgary
grossgary
  • 21,730 posts
  • Midatlantic
Posted 14 March 2013 - 02:00 PM
another Ej18 into EJ22 thread:
http://www.ultimates...-both-auto-awd/
