marcusgl10z28 Posted March 27, 2013 Share Posted March 27, 2013 I need a turbo for my ea82... I think.. Engine makes some raket near the turbo in 1300-2000 rpm range.. some fresh oil residue in intake plenum and smokes at idle and after shutdown.. Most smoke is after shut down.. Seems to run fine.. But stopped driving it... Anyone have a turbo mines vf5 I think Quote Link to comment Share on other sites More sharing options...
NorthWet Posted March 27, 2013 Share Posted March 27, 2013 Most likely IMHO is that your uppipe has cracked at the turbo flange... a very common problem. Oil often comes from PCV system: you might want to check in the rubber inlet boot for oil. I might have an extra turbo lying around. Quote Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted March 29, 2013 Author Share Posted March 29, 2013 ok... ill check now... lemme know f you do have one though... thanks... and i do have a new exhause leak i never heard befor seems to be coming from that area Quote Link to comment Share on other sites More sharing options...
marcusgl10z28 Posted March 29, 2013 Author Share Posted March 29, 2013 just looked annd yup... its got an fair coat of oil in it and in the maf... what on earth would cause that... its no over filled with oil... Quote Link to comment Share on other sites More sharing options...
NorthWet Posted March 29, 2013 Share Posted March 29, 2013 PCV system needs some attention. The PCV valve itself may need replacing. The cam-cover PCV vents tend to gunk-up and narrow (easily visible if you pull the hoses off of the cam-covers), and this tends to pump oil upwards. The breather at the back of the block (near the timing window of the bell housing) might also be gunked up... as might the hoses. Check over the entire system, but BE GENTLE with the molded hard-plastic "tree that all of the PCV hoses connect to: It tends to get brittle with age, heat and oil, and may be impossible to buy new. Quote Link to comment Share on other sites More sharing options...
