mgcwrnch Posted April 1, 2013 Share Posted April 1, 2013 After much help from "The Guys" here, the wagon is a jewel. Two relays under the passenger carpet, I finally found them, were rusted to death. Replaced from O'Reillys. Still would not idle. Tach would bounce, then would stop running. Yes, it was the Dizzy. Worn upper bearing. Had it machined out and replaced with an oilite bearing, watching all tolerances. $3.58 at a bearing supply house. Friends work was a freebie. :-))) Pic of the installed Oilite. Now to pass California smog test. Quart of Lacquer thinner in tank, should clean out old gas and gum. Alan Quote Link to comment Share on other sites More sharing options...
naru Posted April 3, 2013 Share Posted April 3, 2013 (edited) Glad to hear you got her going fairly easily. I really like mine too. Edited April 3, 2013 by naru Quote Link to comment Share on other sites More sharing options...
rdweninger Posted April 3, 2013 Share Posted April 3, 2013 Lacquer thinner in the gas tank??? Does this work... anyone with good or bad results? Quote Link to comment Share on other sites More sharing options...
