Can you tell me where these vacuum hoses go?
11 replies to this topic
#1 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 08 April 2013 - 12:16 PM
One of is cut with a bolt in it which is connected to the egr valve he other is cut and is goin to a canister under the air flow box on the right hand side of the engine both are capped but cant find where they go the egr valve light is on but the car is running and i think the anti back fire has been removed im posting this bc my gas mileage is like 15mpg its an 87 2bl 1.8 gl station wagon
Edited by Lacyjs9, 08 April 2013 - 12:20 PM.
#2 mikaleda
mikaleda
    legacy specialtist
  • 2,261 posts
  • priest lake, Idaho
Posted 08 April 2013 - 01:19 PM
it's hard to tell by the pics but it looks like either the vaccume booster hose or the pcv system hose, im leaning to the latter, but it looks like its blocked so i wouldn't think thats whats causing your bad milage.
#3 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 09 April 2013 - 06:41 AM
what about the egr light being on
#4 mikaleda
mikaleda
    legacy specialtist
  • 2,261 posts
Posted 09 April 2013 - 10:12 AM
It might be dirty, wich if it were to get stuck open would cause symptoms of a vaccume leak.
#5 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 09 April 2013 - 10:24 AM
the car runs fine i do have kind of a high idle in park its at 1 and a half and in drive its at 1 i dont understand why im getting poor gas mileage
#6 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 09 April 2013 - 10:30 AM
teh larger hose off breather is a vent for air injection should be two that just vent go to nothing they are fresh air in
#7 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 09 April 2013 - 10:34 AM
so should i un cap it? if i take the bolt out of the egr valve hose it dies
#8 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 09 April 2013 - 10:39 AM
i would look closer and look in manual to make shure also should be vacume diagram under hood thiss one is most acurate diagram you will get
#9 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 09 April 2013 - 10:41 AM
Also check hose to antibackfire valve is not pluged or blocked and has strong vacume to it on those cars this is what i see go wrong most pluged at egr valve
#10 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 09 April 2013 - 11:19 AM
i think the anti back fire valve is gone
#11 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 09 April 2013 - 11:47 AM
ok after burn valve has been removed but everything has been capped off but egr valve light is on should i replace this or what?
#12 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 10 April 2013 - 10:19 AM
or just block egr off those cars realy liked there antibackfire valve i whould reinstall one if you can find it the stock carb setup worked realy good but had a ton of stuff hooked to it. The fact that it has a code means is a feedback carb theese carbs had a varablle main jet that was computer controled and tended to get stuck in one spot mostly on the ritch side. It has default abillity can go full ritch if sees a problem. I whould serch out a 85 -86 carb thats non feedback and try that.
