help my key is stuck in the ignition
A couple other things to try are stepping on the brake, wiggle the steering wheel back and forth as your trying to turn the key off, try switching from drive to park a few times in a row, and try turning the car back on and off again and maybe it will come out.
If none of that works I would suspect the sylinoid that locks the key in when not in park is malfunctioning.
Try hitting the key with a hammer to push it into the ignition more.
Really? I would save that for a last resort, if the key isn't turning off it suggests something's binding it up or it's being locked out for some reason. Hitting it with a hammer could case the tumblers to break if they are binding.
It worked for me.
