ignition timing procedure
5 replies to this topic
#1 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 16 April 2004 - 08:34 PM
I was wondering if any one out there knows the correct procedure for adjusting the ignition timing for an EA81T.I assume you disconnect the vacuum advance but I am unsure what RPM the engine should be running at or what the timing should be set to.Any help would be greatly appreciated.Thanks,Dave.
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,188 posts
  • WA
Posted 17 April 2004 - 04:32 AM
Timing is BTDC 15 +/- 3 deg @ 800rpm
And just plug the disty pressure hose. The timing marks are on top of the crank pulley.
#3 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 17 April 2004 - 08:35 PM
I got it set at 15 btdc.It was at 5 btdc.What a difference correct timing makes.Thanks a bunch Turbone.
#4 dave valiant
dave valiant
    Subaru Nut
  • 570 posts
  • Rapid City
Posted 18 April 2004 - 11:03 PM
Turbone is it normal to be completely out of advance at 15 degrees btdc.I double checked my timing because I had timed it off of cylander #2 instead of #1.It was only off by 2 degrees but when I put it to #1 at 15 btdc it is out of adjustment.Thanks for the help,Dave.
#5 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,188 posts
  • WA
Posted 19 April 2004 - 12:23 AM
The disty could be a tooth off. Or maybe you have the wires on the disty wrong? With the cap off, the rotor should be pointing at 11 o' clock (TDC). Rotation is counterclockwise, and the cylinders are numbered;
3 4
1 2
And the firing order is 1,3,4,2
Check this and report back, eh?
#6 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 19 April 2004 - 09:08 AM
3 4
1 2
http://www.usmb.net/...e=New Image.JPG
fire order is 1 3 2 4
