I tried that already and couldn't get it to come out any measurable difference. The dip stick tube angles in towards the oil pan but along the top it is vertical to pass behind the timing setup.Do you know if the tube itself has to be rotated at some angle to clear everything? or at least come out enough to replace the O ring?
You should have enough room to pull out the dipstick enough that you can get to the oring connections, at least on my '96 EJ22, the dipstick can be rotated forward and pulled up and out but I'd be certain that an earlier dipstick is at least simmilar and you can gain access to the o rings
