LPG conversion...
ea81 propane conversion
36 replies to this topic
#1 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
  • Englewood Colorado
Posted 14 May 2013 - 09:58 PM
Any interests in propane conversion? I have a spare ea81 block laying around and im considering propane conversion just for grins... ive aquirred a book that goes over converting smaller 4 stroke motors but the math should all carry over. ive seen kits for v8 motors but none for smaller. I may use an existing carter webber that i have being a single barrel, or the hitachi seeing that those are more common. other option is just to fab a new one up from scratch, and might be the easier route.... any one ever try this?
#2 ford'ssubaru's
ford'ssubaru's
    Eat, Live, Breath Subaru
  • Gold Subscribers
  • 282 posts
  • SPOKANE
Posted 15 May 2013 - 10:07 AM
Speaking from an industrial mechanic's point of view which only means really work on LP units every day.  I would love chat this topic not even something I would want to do myself personally.  Have a couple of questions though.
1.  Are you very patient?
2.  Do you have a lot of spare time?
3.  Do you plan on driving this everyday?
There are so many variables that are just different with LP.  For instance...  Many people try to do this conversion on an engine with high miles.  They think that since the engine is within specs according to a Chilton or Haynes it is OK for LP.  Compressions have to higher and more even simply because LP is more sensitive to compression differentials.  Then they try to adjust regulator or regulators cylinders that are uneven.  It will run good till warm.  It will run bad cold then runs good.
Cheers,
Eric
#3 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 15 May 2013 - 10:21 AM
I ran propane on a subaru 3.0 six with turbo worked very well and we have some ej motors runing on propane all turbo works well we use a cut down ej 2.2 harness with just spark wireing no efi
#4 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 15 May 2013 - 05:06 PM
cool this gives me hope! The motor however is probably a higher milage and to be honest the condition of it is uknown. I just happen to have it lying around and a couple spare carbs, and all the free time I need currently. plus it sounded fun!
#5 rdweninger
rdweninger
    USMB Regular Nut
  • 790 posts
  • Tillamook, OR
Posted 15 May 2013 - 05:53 PM
At a buck 79 per gallon... I too, have pondered this option.
So what... just strap the propane tank in the passenger seat?
#6 djellum
djellum
  • 797 posts
  • Vancouver WA
Posted 16 May 2013 - 12:17 AM
Id probably look for one that fits in the spare tire compartment (disclaimer on not knowing if there are regulations against this for safety in a head on, you will have to account for your own due diligence).  short run for fittings and hoses, and keeps the gas out of the cabin.  Id try for a dual system if you can.
id also research which stations in your area will fill it, lots may say no.
#7 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,546 posts
  • Puyallup
Posted 16 May 2013 - 07:53 AM
A few things to point out... You can't just throw a regular carb on and go. Won't work. Second, you need a minimum of 9.5:1 compression or a small engine like that will be a gutless t*urd and run like garbage. Third and most important... The tank CANNOT be mounted in the engine compartment or inside the passenger compartment. Aside from the absolute stupidity and safety issues, it's a violation of federal law. You have to have a specially rated horizontal tank mounted where your gas tank was and should build a safety cage around it. Lastly, if you want any kind of dependability out of it, IE: long life, you'll want forged pistons, moly rings and stainless exhaust valves. I'm the LPG tech along with being the driveability and diesel guy at work. I've rebuilt more than a few LPG and propane engines and conversions on carbed rigs time consuming and frustrating. What was #1 at the top of this thread.... Are you very patient? Not trying to discourage you, but you really need to research this. There's a reason LPG didn't really take off until fuel injection came along
#8 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 16 May 2013 - 08:33 AM
we ran a brbq tank upside down in back
#9 rdweninger
rdweninger
    USMB Regular Nut
  • 790 posts
  • Tillamook, OR
Posted 16 May 2013 - 10:56 AM
Gotta love those Canadians !!!
Any chance you tapped the propane to run an auxillary grill for BBQ Tailgaters?
#10 skishop69
skishop69
  • 1,546 posts
  • Puyallup
Posted 16 May 2013 - 04:15 PM
Wow.... is all I can say to that.  :o
#11 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 16 May 2013 - 10:39 PM
yes im well aware of the complexity of the conversion. If I can get said conversion to work on A SPARE MOTOR, I would then transfer the conversion into a car. If it goes that far I will be using a forklift tank mounted in the bed of a brat. who gives a f*ck if it doesnt work either? ever just do something for grins :) :) :) ? I'll have to look into the laws around lisencing the the car for street use, but whats dumb about experimenting with alternative zero emissions fuel any way.
#12 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 16 May 2013 - 10:42 PM
duel fuel system is the dream but I think its going to be for LPG only. And I fill propane tanks all day at my work so avalibility is no issue for me
#13 skishop69
skishop69
  • 1,546 posts
  • Puyallup
Posted 16 May 2013 - 11:16 PM
Never said any of it was dumb EXCEPT for mounting the tank in the cab or engine compartment. I'm all for zero emissions. I also do the hybrids and the Volt. Just pointing out you're looking at thousands of dollars (3 at least) for a safe, viable system.  You legally can't use a forklift tank. Huge fine if you get caught. I'm not trying to be an a**. I just know people who have been killed trying to half a** this stuff, or worse, kill someone else in an accident. I do all kinds of sh*t just for grins. Lifted a J10 pick up 8" with all custom suspension I built. Ramped 786 and would still carry a camper with only 2" of squat. Dumped in a 400hp SB400, 5spd, 3/4  ton corporate Chevy running gear and built a 30 gallon fuel cell for it since the pos came with a 16 gallon tank. people asked why.... Because I can! lol I get it. I'm just saying don't cut corners and do lots of research.
#14 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 17 May 2013 - 09:15 AM
The tank and setup was in ofroad buggy not street car we used that tank cause is all we could fitt in sutch limeted space
#15 ford'ssubaru's
ford'ssubaru's
  • Gold Subscribers
  • 282 posts
  • SPOKANE
Posted 17 May 2013 - 09:17 AM
I too have done all kinds of stuff just to do it...  I did just want to point out some facts.  I don't know skishop69 but seems to be your go to guy.  I do like the topic though  because it is something I work with.  As I was looking at a forklift tank mount figuring out how to invert it mout it to have REMOVEABLE 15 gln. tank.  I also think there is a tank valve head cap law that is required?  Similar to putting tank caps on my bottles in my service van.  Even started staring at an indistrial IMPCO system only because it is simple looking....  So I too don't think it is dumb.  I think skishop69 was also just giving you facts.  Love your thread.
Eric
#16 capn_r
capn_r
    Pseudo Soob Noob
  • 363 posts
  • Morton WA
Posted 17 May 2013 - 09:25 AM
NFPA 58 is the source for US LPG information.  Check it out.
#17 m12-lrv
m12-lrv
    New User
  • PipPipPip
  • 50 posts
Posted 17 May 2013 - 10:46 AM
As far as im probably going to get with this is making the carb and at least get a motor to run on a stand. I want to document my trial and error on doing this so if someone wants to build a motor more specifically around running on LPG they can take what I come up with and run with it.
#18 LPGsuperchargedBrumby
    Fully retarded and low on compression
  • 665 posts
  • Dunedin, NZ
Posted 11 June 2013 - 02:22 AM
I have my EJ swapped Brumby running dedicated LPG and have done now for 7 years....i swapped it to LPG when it still had the EA81 in it(supercharged it for a bit until i got sprung by Mr Plod), did about 25'000 miles before it spalled the cam (have suspicions about the oil i was running being the cause) swapped in a EJ18 (really high mileage= cheap, needed the vehicle going 'now') carb and dizzy motor ran that for 10'000 miles until it dropped a valve then swapped in the good EJ22 9aslo carb and dizzy) thats in it now....that has over 100'000 miles on it.
one thing if you are going to convert it to LPG is to use a variable venturi like an IMPCO....i started with a fixed venturi because i didn't know better then swapped to a variable (BLOS)...the difference is unbelivable
the impco CA 55 mixer is bang on the right size(hp rating) for a EA81....altho you will not be able to mount it on top of the factory carb and still close the bonnet.
i fitted it all myself....lol i started out not knowing anything much about LPG tuning and now i get the occasional phone call (from the installers where i get the annual safety check thats needed here done) saying "um...can you come have a look at this?"
also have a 12.5-1 compo EJ25 with SOHC EJ20 heads and delta torque cams that i need to finish putting together....that should run well on LPG
Edited by LPGsuperchargedBrumby, 11 June 2013 - 02:25 AM.
#19 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 12 June 2013 - 08:41 AM
Matt bought a realy cool mpi propane setup was showing me last night tees into the injector feeds and can run deul feul was very neat looking kinda like a vortec mpi but with propane. We are going to test it on untested 2.5 stroker turbo engine has 10-1 comp roller cams and turbo legacy heads with mpi propane should work good
#20 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 12 June 2013 - 11:24 AM
You absolutely can use it as long as it is above the bed.
They add propane to cummins diesels all the time, and it's perfectly legal as long as the tank is above the bed and secured.  BBQ tanks are even fine like that.  It's a below deck or "enclosed" installation that requires specifically certified tanks (like RV tanks)
#21 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 13 June 2013 - 09:24 PM
Why wouldna an existing 2.4 l kit work on a 1.8 liter?
#22 LPGsuperchargedBrumby
  • 665 posts
  • Dunedin, NZ
Posted 14 June 2013 - 08:12 AM
It might....but if it has a fixed venturi mixer (as against a variable venturi like an IMPCO) it will probably run like a dog at idle if it runs at all at idle....same result as if you put too big of a carb on a 1.8....which is what your doing
#23 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 14 June 2013 - 01:09 PM
I would suppose that the fuel cylinder from an RV would be of the right type to be made road legal
#24 capn_r
capn_r
    Pseudo Soob Noob
  • 363 posts
  • Morton WA
Posted 14 June 2013 - 02:28 PM
An RV tank that has a liquid port is fine as long as it is mounted in an  approved safe location.
#25 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 14 June 2013 - 03:18 PM
You could refuel at a lot of U-Haul locations by the gallon.
