EJ22T swap issues
34 replies to this topic
#26 Gloyale
Gloyale
    It's a sickness
  • 10,938 posts
  • Corvallis, OR PNW
Posted 06 June 2013 - 11:06 AM
 I can do a mobile service and come up and get it running if you want.  If you're getting CEL, power from the relay, you are really close.  Don't give up yet.
ALOT cheaper than an aftermarket ECU.  Plus your gonna have to wire up and program the aftermarket ECU anyhow.
#27 Numbchux
Numbchux
    EJ conversion addict
  • 6,890 posts
  • Saginaw, MN
Posted 06 June 2013 - 12:19 PM
welll regrounding did absolutely nothing lol
What it sounds like is happening:
ECU must not be powered properly.
Your next step:
Pull up an ECU pinout for your ECU, and triple check that you have good power and ground to all the wires that need it.
#28 sikend667
sikend667
    New User
  • PipPipPip
  • 73 posts
  • vancouver wa
Posted 10 June 2013 - 08:38 PM
ok ill go thru and probe everything this weekend see if i missed somthing
thank you again guys for the help so far and gloyale if i wasnt broke and it wasnt a 4 hour drive id take u up on that lol
Edited by sikend667, 10 June 2013 - 08:40 PM.
#29 Gloyale
Gloyale
    It's a sickness
  • 10,938 posts
  • Corvallis, OR PNW
Posted 11 June 2013 - 12:37 AM
Corvallis is barely 2 maybe 2-1/2 hours.
#30 sikend667
sikend667
    New User
  • PipPipPip
  • 73 posts
  • vancouver wa
Posted 11 June 2013 - 12:57 AM
4 hours total :)
#31 Gloyale
Gloyale
    It's a sickness
  • 10,938 posts
  • Corvallis, OR PNW
Posted 12 June 2013 - 11:18 AM
Probably make it back up in less than an hour once that EJ22T is hummin' :)
#32 sikend667
sikend667
    New User
  • PipPipPip
  • 73 posts
  • vancouver wa
Posted 17 June 2013 - 08:57 PM
ok so i did it finally got pissed off enough and bought an aftermarket ECU....... will be wiring it up this weekend and pitching the factory computer in the pile of subaru crap for testing lol
#33 ironoxide
ironoxide
    New User
  • PipPip
  • 10 posts
  • Logan
Posted 01 July 2013 - 02:43 AM
I almost guarantee you cut out the Diode, and inherently the power wire to the ECU....
I've done this before, and now know to keep that little section. Nobody really tells you about it in Swap Explanations though.
#34 Gloyale
Gloyale
    It's a sickness
  • 10,938 posts
  • Corvallis, OR PNW
Posted 01 July 2013 - 12:23 PM
+1
#35 heartless
heartless
    Do YOU Subaru?
  • 3,343 posts
  • North Central Wisconsin
Posted 02 July 2013 - 07:50 AM
Perhaps "somebody" should to avoid this problem for others?
