1980 Brat, clutch cable keeps breaking
4 replies to this topic
#1 danrenfroe2016
    USMB is life!
  • 225 posts
  • Dallas, Texas
Posted 21 May 2013 - 05:55 PM
Clutch cable. I have broken two now. I do drive my brat everyday, but two clutch cables in less than 5 years is kinda crazy. I just replaced the clutch, pilot, plate, had the flywheel ground (two step). I get it all back together and then snap! another clutch cable gone. this time it broke at the top near where it attaches to the pedal. Any Ideas? -Daniel
#2 talldude
    USMB Regular
  • 163 posts
  • Placerville
Posted 21 May 2013 - 11:26 PM
Maybe poor quality cable?  I know aircraft cable suffers when it loses its lubricant- you might soak the cable in a light penetrating oil and make sure it has grease where it attaches to the pedal pin.  Also watch it through full movement in case it is abrading anywhere through its travel. Any sharp corners?
#3 danrenfroe2016
    USMB is life!
  • 225 posts
  • Dallas, Texas
Posted 22 May 2013 - 11:11 AM
Ok, I think when the pedal is up (Cluch engaged) the cable is getting bent a bit to much. I will re-adjust and try the new cable when it comes.
and yes... AUTOZONE!
Oh and I will lube it good this time.
#4 moosens
    Vintage Subathusiast
  • 1,945 posts
  • Bridgeport CT
Posted 22 May 2013 - 06:32 PM
Get your face down there and push clutch with your right hand. Watch the metal flex by the pivot pin, just below it. That and routing. I know I need to work both out before I'm happy with mine.
My pedal box was welded already. Check yours for a stress crack. Once it happens it just gets worse.
#5 danrenfroe2016
    USMB is life!
  • 225 posts
  • Dallas, Texas
Posted 23 May 2013 - 07:26 PM
yes I have noticed the flex. I will look in to it. now about my broken bolt...
