Dry Sump on a 2.5L?
10 replies to this topic
#1 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 29 May 2013 - 05:06 PM
Just wondering if anyones done it?   Seeing how the oil pan ends up being one of the lower points of the engine I'm wondering if a dry sump oil system would work?   It would also raise the capacity of the oiling system and eliminate aeration of the oil..
#2 sikend667
sikend667
    New User
  • PipPipPip
  • 73 posts
  • vancouver wa
Posted 29 May 2013 - 08:23 PM
do some searching. i know that its been done and i even looked into doing this on my eg33 build:
http://www.daileyeng..._4_cylinder.htm
i think cosworth has a system as well
Edited by sikend667, 29 May 2013 - 08:23 PM.
#3 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 30 May 2013 - 11:55 AM
no prices.So I guess it follows the rule of if you have to ask, you can't afford.
#4 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 30 May 2013 - 12:33 PM
found this:
http://performancefo...mp-construction
#5 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 30 May 2013 - 03:56 PM
The commercial units are pretty spendy (as in, more than I have ever paid for a car).  I have been considering something much more shade-tree:  Use the existing oil pump as the scavenge pump and using a power steering pump (or similar) as the pressure pump.
#6 sikend667
sikend667
    New User
  • PipPipPip
  • 73 posts
  • vancouver wa
Posted 30 May 2013 - 11:10 PM
the daileys eg33 is 6250 i know cuz i came close to ordering one lol. i dont understand why it wouldnt work my only concern would be scavenging from the heads and what type of secondary container you use
#7 torxxx
torxxx
    I void warranties
  • 2,918 posts
  • Fairbanks
Posted 31 May 2013 - 12:23 AM
holy S@#%.... thats worth more than all 11 of my subarus.....
#8 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 01 June 2013 - 03:03 AM
why not use the factory oil pump as the high pressure then get a single stage scavenge pump.Then just mount the oil tank higher than the factory oil pump and have it gravity feed into the inlet of the factory oil pump.A power steering pump is high pressure but at low volume so it wouldn't really work well.
#9 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 01 June 2013 - 03:31 AM
The reason to use the stock pump as scavenger is because it already does that without any extra work.  Just run a remote filter adapter (really cheap at Amazon.com) to your tank, and from the tank to the external pump.  Lots of things to consider and check to make it work, but that goes without saying.
I don't recall the flow specs on an EJ, but the PS pump puts out around twice the flow rate as an EA82 oil pump.  And greater flow rate pumps are as close as your auto dismantler.
#10 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 01 June 2013 - 10:28 AM
I know there is low pro pans for vw vans with subaru engines
#11 presslab
presslab
    Subaru Nut
  • 868 posts
  • N. California
Posted 01 June 2013 - 10:39 AM
I shortened the oil pan on the EJ25 in my Vanagon by about 1.5" and put 1/8" steel plate on the bottom.  There is also Smallcar, Outfront, Kennedy, Rocky Mountain Westy, and Burley Motorsports who make shortened pans, with varying capacities.
Edited by presslab, 01 June 2013 - 10:39 AM.
