Tranny gurus, I have a question.
22 replies to this topic
#1 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 02 June 2013 - 04:18 PM
I have to r&r the tranny in my dads 91 Legacy wagon. Its an automatic. Yesterday I pulled an auto tranny from a 90 legacy sedan and when I got it home I noticed the diff dipstick on the 90 tranny was taller than the 91 tranny. So my question is, what are the differences between these two trannys, and is it a direct swap? Both trannys have a rear gear ratio of 4.111. Thanks guys.
#2 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 02 June 2013 - 05:31 PM
as long as the years you quoted are correct, it is a direct swap.
no issues.
#3 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 02 June 2013 - 05:38 PM
Ok cool thank you.
#4 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 06 June 2013 - 04:44 PM
When pulling the tranny, are you supposed to remove the torque converter at the same time? I've never pulled an auto before. I got the tranny out last night, but the input shaft is still sticking out of the tc. The tranny I pulled from the junk yard came out easy.
#5 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,034 posts
  • Charlottesburg, VA
Posted 06 June 2013 - 04:53 PM
Yes you should remove the torque converter with the transmission.
Search here for how to properly seat the torque converter (there is a good thread with pictures somewhere on this forum) before trying to install the transmission. You need to get the converter seated properly first, otherwise it will damage the fluid pump in the transmission, and your "new" trans will be a boat anchor.
Also do not drop the converter when removing it from the flex plate! It is only partially supported by the pilot stub in the center.
Edited by Fairtax4me, 06 June 2013 - 04:57 PM.
#6 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 06 June 2013 - 08:48 PM
How am I supposed to get that shaft out of the torque converter? I'm about ready to have my dad go get a new one.
#7 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 06 June 2013 - 09:33 PM
This is my problem.
#8 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,034 posts
Posted 06 June 2013 - 10:44 PM
Nice!
That stayed in the new trans correct?
Vice grip the end, smack the vice grips upward with a big hammer.
#9 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 06 June 2013 - 11:42 PM
Ohhh nice!! Never seen that one yet!
#10 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 07 June 2013 - 12:17 AM
Yikes.
Nothing to do but pull on that sucka.
#11 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 07 June 2013 - 12:29 AM
Yeah, it didn't stick in the tc from the doner car.
#12 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 07 June 2013 - 12:32 AM
You can swap out the unstuck TC and input shaft.
#13 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 07 June 2013 - 08:43 AM
I could, but my dad had this one installed along with a new flexplate a year or so ago. Mabey I should just do that.
#14 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 07 June 2013 - 09:55 AM
oh the wonderfull 4eat !
#15 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 07 June 2013 - 10:44 PM
I got the input shaft out of the tc, but I cant get it to seat in the tranny. I don't know what I'm doing wrong, I've been reading this thread http://www.ultimates...rque converter over and over again for the last 2 hours and can't get the tc past the first stop. What's goin on here?
#16 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 09 June 2013 - 11:12 AM
i spin it and push inwards gentaly take a lot of time somtime to get it to seat make shure tc extetion is cliped to tc
#17 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 09 June 2013 - 11:20 AM
Yeah I tried again for a couple hours yesterday, still no dice. I don't know what the deal is.
#18 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 09 June 2013 - 11:25 AM
take it back out try the shaft in the torque make shure will go in off the trans also is shaft right way round ? check closly all splines for damge check sealing rings close for damge you could try install without shaft in trans just to see whats hanging up check the spline one fixed stator spline easy to damge the splines Try and figure out what part of its hanging up
#19 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 09 June 2013 - 02:33 PM
Ok yeah ill try to install it without the shaft and see if it'll go on then go from there. Thanks for the idea.
#20 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 10 June 2013 - 09:11 AM
any luck ?
#21 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 10 June 2013 - 12:04 PM
No, wouldn't even go on without the extention. I wonder if I messed up the tc when I removed the tranny. Might have to go get the tc off the car I got the tranny from.
#22 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 12 June 2013 - 08:36 AM
Did you check fixed stator spline the large one of front of trans look very close for craks or deformation sounds like its damaged
#23 espey_16
espey_16
    USMB Regular
  • 328 posts
  • Tenino Wa
Posted 12 June 2013 - 11:53 AM
Yeah, everything looked good, I think it might be something in the tc itself. Friday I'm gonna go get the tc from the donor car and see if that will work. If not, ill return that tranny and pull another one. The right way this time though.
