1-3-2-4 Posted June 8, 2013 Share Posted June 8, 2013 (edited) Wondering if it's going to fit in the trunk of a '95 Ford taurus? I can't really find any info Well the most I found is here http://www.sdsefi.com/air11.html If that's the case then it should be no issues with everything still on then, I should be able to lift it out with the engine lift. Edited June 8, 2013 by 1-3-2-4 Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 9, 2013 Share Posted June 9, 2013 I'm pretty confident it will fit in the back of the Taurus, I've had a Toyota w56 trans with t-case in the back of my legacy sedan with little issue and it still had the shifters installed making it a little taller than an ej. The Taurus in those years was about the same trunk size if I remember correctly. 1 Quote Link to comment Share on other sites More sharing options...
987687 Posted June 9, 2013 Share Posted June 9, 2013 I've fit an ej22 with the crank pulley and bottom bell housing studs removed into the back of a first gen impreza sedan.... A taurus is much larger than that. Also a good trick is to remove the spare tire, gives a huge amount of extra room in the trunk of any car. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 14, 2013 Author Share Posted June 14, 2013 Well if I can't find one that's an AT model for testing I'm just going to let it sit until I get the Cometic Head Gasket EJ22ET set so I can put the 2.5 DHOC heads on and have the coolant passages line up right, besides the amount of rain we had here in the past week I doubt I can get the engine lift out of the basement with all that soggy soil. Quote Link to comment Share on other sites More sharing options...
987687 Posted June 14, 2013 Share Posted June 14, 2013 If you're putting 2.5 heads on a 2.2, you should use 25 headgasktes. Otherwise the firing ring will be inside the head chamber. Auto and manual engines interchange, so that doesn't matter. You need to use a flexplate that matches the transmission, anyway. Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted June 14, 2013 Share Posted June 14, 2013 That is untrue. You want the gasket to match the bores. There is a reason all the ej22t dohc hybrid builds run ej22 head gaskets. Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 14, 2013 Author Share Posted June 14, 2013 I ordered these.. I must of taken the last two because now they say they wont be in stock until July. http://www.rallysportdirect.com/Cometic-Head-Gasket-EJ22ET-MLS-98MM-051-Subaru-Legacy-Sport-1991-1994 With that HG the coolant passages will match the ej25 heads Quote Link to comment Share on other sites More sharing options...
ivans imports Posted June 14, 2013 Share Posted June 14, 2013 So engine in the trunk hook the trans and cvs up and you have one fast ford Quote Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 14, 2013 Author Share Posted June 14, 2013 Haha this car's weight makes it so slow, I've gotta start calling some of these places to see what's the prices are, what I have a feeling I will be doing is just getting the heads today.. Only because I don't have a place to put the engine right now and I in no shape or forum will be trying to lift that engine myself (I'm 126 Lb) The 5MT from a dead lift was bad enough but once in your hands it was easy as pie. I can get the L&R heads for about $150 and at least I wont have to worry much about rain on it since it's muddy like crazy.. Sounds like the better option, then on the day of the swap (sometime next week) get the engine and pull the engine lift out, because I still have to wait for those cometic gaskets I ordered anyways. Quote Link to comment Share on other sites More sharing options...
