DIY Leak down tester
4 replies to this topic
#1 Carl B.
Carl B.
    USMB Regular
  • 129 posts
  • Colorado
Posted 09 June 2013 - 01:47 PM
I attached an image of a leak down tester I made to find the right motor for my EJ swap.  Also the link to a forum that has a writeup to build your own.  Mine is a little different because I used some things I already had in my tool box.  I havent used it yet but I'm going to check out an engine candidate today, I'll let you  know how it works.
http://forums.bimmer...d.php?t=1421365
#2 JordanR693
JordanR693
    USMB Regular
  • PipPipPip
  • 96 posts
  • Louisville
Posted 09 June 2013 - 05:24 PM
it will work just take the shrader valves out of the compression guage hose
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,755 posts
  • East Coast
Posted 09 June 2013 - 08:37 PM
nice hit, i've been wanting a leak down set up to put compressed air in the cylinders.
ring and valve issues are rare on EJ engines but at least you can rule those out, can't really test the main concerns like bearings.
don't forget  www.car-parts.com, i guess you're in colorado which has some high pricing for Subaru's but i've paid $150 - $300 for EJ18's and EJ22's with a warranty and 125,000 miles or less.
#4 Carl B.
Carl B.
    USMB Regular
  • 129 posts
  • Colorado
Posted 14 June 2013 - 06:33 PM
So the tester worked okay.  Got some readings that were all over the place, but think it had to do more with finding a perfect TDC.
#5 Gloyale
Gloyale
    It's a sickness
  • 10,642 posts
  • Corvallis, OR PNW
Posted 16 June 2013 - 02:52 PM
Leakdown doesn't need to be done at TDC.....just valves closed.
Infact, if an engine has good compression, putting air to it will force the piston down to the bottom.
Wanna really test?....install the leakdown tester with a cylinder bottomed out, then turn the crank with a wrench fairly quickly.......It should try to "bounce" back.
