95 Impreza 4eat makes noise in gear
6 replies to this topic
#1 redXTwedgie
redXTwedgie
    Advanced Member
  • PipPipPip
  • 84 posts
  • portland or
Posted 25 June 2013 - 03:47 PM
I just bought this autopmatic 95 Wagon and although the transmission shifts fine, it starts to make like a metal brushing sound as soon as it is put in any gear.  No sound in park or neutral.  Kind of a "ZZSSSHHHHHHHH".  It sounds like metal brushing or scraping metal with a lot of surface contact.  Not a concentrated sound like a bearing.  Trans works great otherwise.  If the brake band was out of adjustment, I would think it would shift funny, but I've never had a brake band issue before in the dozen or so 4eats I've had.
Any ideas?
Steve
#2 redXTwedgie
redXTwedgie
    Advanced Member
  • PipPipPip
  • 84 posts
  • portland or
Posted 25 June 2013 - 04:57 PM
It seems like the whine changes pitch with the locking/unlocking of the torque converter.  Do those make noise when they go bad?  No noise when coasting in gear until approaching a stop when the torque converter has to work.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,050 posts
  • Charlottesburg, VA
Posted 25 June 2013 - 11:17 PM
A member here, Presslab, just recently took one apart where a bearing/bushing in the converter had failed and was making a whining sound similar to a pump going bad when in gear. Upon disassembly the output of the converter was very loose. Replacement of the converter fixed the noise.
Edited by Fairtax4me, 25 June 2013 - 11:18 PM.
#4 redXTwedgie
redXTwedgie
    Advanced Member
  • PipPipPip
  • 84 posts
  • portland or
Posted 26 June 2013 - 02:31 AM
Cool, I'm hoping its just the converter.  I'll have the engine out soon and I guess i'll drop in a new converter while i'm in there.  Thanks.
#5 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 26 June 2013 - 10:30 AM
front pinion berring on the pinoin shaft were it contacts the crown gear pull magnet plug from front diff and check for meatal shavings or bitts. If thiss go's it alows the tail shaft to contact transfer gears making those noises
#6 redXTwedgie
redXTwedgie
    Advanced Member
  • PipPipPip
  • 84 posts
  • portland or
Posted 06 July 2013 - 03:40 AM
I went to the junkyard to get a torque converter and found a 97 2.2 (mine 95 2.2) that already had the motor pulled.  I yanked it out and was out of there in 2 seconds and put tried to put it on and it wouldn't fit the input shaft.  The smallest tip part had 22 teeth vs. 24 on the other one.  I had to go back to JY and yank the input shaft to make it fit.  The inner end is also slightly different but fit ok.  I'll have the motor done tomorrow to see how it works.  My TC, you could spin it with your finger and it would remain spinning for 2 seconds. :o  Most likely the source of the noise.
#7 redXTwedgie
redXTwedgie
    Advanced Member
  • PipPipPip
  • 84 posts
  • portland or
Posted 07 July 2013 - 11:22 AM
That got it working good.  I stuck my new frankenmotor in front of the TC and life is good for now.
