79 Brat with an EA81 transplant in it
5 replies to this topic
#1 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
  • Mt.Vernon Washington
Posted 25 June 2013 - 11:38 PM
Does anyone know if the stock EA71 fuel pump is strong enough to pump to an EA81? Im having a fuel Delv. issue and not sure what would be causing it,  Also does anyone have pics on how the EA81 D/R lever was set up I just need a few Ideas
https://www.facebook...t=photo_comment
That's the new project , not sure it worked (the link)
Jeff
#2 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 26 June 2013 - 10:39 AM
My 81 brat is old body with ea81 high low factory trans is a bitt dif were shifter gos and has high low on dash and tach. I made it spi thiss made it run way better. The ea81 uses a retuing sestem the ea71 dose not i think you can put the spigot from ea71 carb to ea81 carb thiss may help alos try boling back thru lines into tank mine had s--t in the lines or sock at the tank and was just barly geting feul thru
#3 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Sorry blowing thru
#4 one eye
one eye
    I'm A Subaholic
  • 2,593 posts
Posted 26 June 2013 - 08:21 PM
fuel is pumping out not sure if its enough pressure though..............................
Jeff
#5 Subruise
Subruise
    Official Party Pooper
  • 1,568 posts
  • pierce county
Posted 26 June 2013 - 11:21 PM
that thing had a bees nest in the fuel door when i got it :/
#6 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 27 June 2013 - 09:43 AM
I i had a $ for every mud wasp nest that caused me grief in every spigot hose hole you name it preshure is erelavent flow is what matters on the ea81 they had a fillter on the neddle seat that realy liked to plug up and is only acsess from inside carb have had many problems with this screen pluging
