weird tick
14 replies to this topic
#1 Frankinsubi
Frankinsubi
    Member
  • PipPip
  • 19 posts
  • Moscow id
Posted 27 June 2013 - 11:58 AM
Hello guys. so i have been trying to figure out what this ticking in in the loyale maybe someone here has an idea.
When the car in parked and in idle and i then rev the engine it sounds good and normal no tick but then while driving anytime that i am really on the gas there is a really fast tick tick and it goes away when i stay on the gas but just i bit softer then while ticking.   I am stumped please help if you can i would like to fix it.
#2 mikaleda
mikaleda
    legacy specialtist
  • 2,263 posts
  • priest lake, Idaho
Posted 27 June 2013 - 12:36 PM
Search for tick of death, it's a fairly common problem on these engines. More than likely its just time for a new oil pump.
#3 Señor Brat
Señor Brat
    USMB Regular
  • PipPipPip
  • 79 posts
  • The Great NW
Posted 28 June 2013 - 05:24 PM
what he said ^^^
#4 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 28 June 2013 - 07:35 PM
What kinda gas are you using? 85? 7? Maybe it's not ticking but pinging. Try 93 octane gas and see if it is still doing it. Check your timing too.
#5 Subaru_dude
Subaru_dude
    1000+ Super USER!
  • 1,543 posts
  • Morristown, TN
Posted 28 June 2013 - 10:23 PM
Could also be an axle. Is it rpm related or more speed related?
#6 scoobiedubie
scoobiedubie
    USMB is life!
  • 701 posts
  • Aloha, Oregon
Posted 29 June 2013 - 10:04 AM
Possible speedometer cable inside of the instrument panel. It only ticks when you are moving.
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 29 June 2013 - 10:47 AM
All of these are good suggestions. If its the lash adjusters, consider the iop lump seals and or the cam tower o rings. Otherwise may not be anything detrimental, and easy to deal with
#8 l75eya
l75eya
  • 2,371 posts
  • Hoboken, NJ
Posted 29 June 2013 - 11:11 AM
Positive miles meant 'oil pump' there. Probably typing on a phone.
#9 jeryst
jeryst
    USMB Regular
  • PipPipPip
  • 120 posts
  • western PA
Posted 29 June 2013 - 09:51 PM
You really need to determine if the sound is engine related or coming from some other component.
Does it change if you are turning left vs going straight vs turning right?
If you only hear it when the car is moving, it's probably a drive train component and not the engine.
I had a sound I couldnt figure out one time, and I took the car to a garage that had a device they called a "Chassis ear".
Not sure if thats what it's really called or not, but its pretty cool. They attach wireless sensors to different parts of the chassis
and take it for a road test. A technician in the car has a receiver with headphones, and he can select each sensor individually
to determine what area the sound is coming from. Once they isolate the area, they then move all of the sensors to that area
and do it again, pinpointing the sound even further.
#10 mikaleda
mikaleda
    legacy specialtist
  • 2,263 posts
Posted 30 June 2013 - 09:12 AM
The cheap version is a long screw driver, put the tip on the spot where you think the noise is and put your ear up to the handle, that an easy way to pinpoint the sound.
#11 l75eya
l75eya
  • 2,371 posts
  • Hoboken, NJ
Posted 30 June 2013 - 11:04 AM
That would be fun to try and do while taking it for a test drive =P
#12 mikaleda
mikaleda
    legacy specialtist
  • 2,263 posts
Posted 30 June 2013 - 06:45 PM
Oops lol, ya that would take a really looooong screwdriver. This is a good way to find a sound on the engine while its running though.
Edited by mikaleda, 30 June 2013 - 06:45 PM.
#13 Frankinsubi
Frankinsubi
    Member
  • PipPip
  • 19 posts
  • Moscow id
Posted 02 July 2013 - 07:28 PM
The sound is only there when the car is moving and when i am really stepping on the gas. then when i let of the gas just a small amout at any speed it will go away...i can rev the car all i was in neutral and there is no tick at all. there are no knocks or anything.
#14 l75eya
l75eya
  • 2,371 posts
  • Hoboken, NJ
Posted 02 July 2013 - 11:36 PM
really sounds to me like you need to use better gas and have your timing checked out. when was the last time you had it tuned up? read the posts above and answer our questions. we're trying to help but we can't do that without you helping us to help you.
#15 Vortex
Vortex
    New User
  • PipPip
  • 15 posts
  • Hervey Bay, QLD
Posted 03 July 2013 - 12:53 AM
I have a similar tick in my XT, but it's always ticking. Give it a go on some premium unleaded if you aren't already doing so.
