runnin hot
5 replies to this topic
#1 elchicharo2000g20
elchicharo2000g20
    Newbie
  • Pip
  • 3 posts
  • south gate california
Posted 28 June 2013 - 01:16 PM
hello every one I have a problem whit 06 Tribeca is runnin hot on idle I replace the radiator because is cloge  on one side but still I replace the wather pump still the same thermostat still I due block test and no problem I by pass the oil cooler the heater and the same I don't no whats the next thanks
#2 coolskaterkid
coolskaterkid
    USMB Regular
  • 145 posts
  • south lake tahoe
Posted 28 June 2013 - 02:19 PM
Are the electric fans working? If it has electric fans?
#3 elchicharo2000g20
elchicharo2000g20
    Newbie
  • Pip
  • 3 posts
Posted 28 June 2013 - 02:30 PM
Hi yes working perfect start between 214 and 220 the problem is they don't stop for the same
#4 coolskaterkid
coolskaterkid
    USMB Regular
  • 145 posts
  • south lake tahoe
Posted 28 June 2013 - 03:06 PM
So the fans will just keep running and it keeps heating up? But it doesn't heat up going down the road? Sounds like an air flow or water flow problem to me. Thermostat should be changed also, use Subaru brand. Maybe you have air in the system from when water pump and radiator changed. Was the system burped to get air out.
#5 elchicharo2000g20
elchicharo2000g20
    Newbie
  • Pip
  • 3 posts
Posted 28 June 2013 - 03:26 PM
yes when the car is on the road no problem, I change the thermostat  I bleed the system like they said, even I put the car whit the front  up  I try vacuum the system and the same I think I have water flow problem because I put the coolant flush machine and no problem the fan work and stop normal
#6 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 28 June 2013 - 04:06 PM
What kind of thrumastat? A Subaru one? Or cheap knock off from parts store?
Oem stant #48457
Subaru's are very specific when it comes to thrumastats.
