ABS Relays - dealer only part?
3 replies to this topic
#1 Max Power
Max Power
    USMB Regular
  • PipPipPip
  • 38 posts
  • Chicago, IL
Posted 20 April 2004 - 08:27 AM
I have a bad ABS relay in my 97 OB. Diagnosing the problem was the easy part, and now I am determined to find a replacement relay without going to the dealer. Has anyone found a source for ABS relays used in Soobs other than the dealer?
How about other vehicles that use the same relay? The bone yards in my area rarely have Soobs, but I doubt the relay is specific to Subaru vehicles.
If the dealership is my only option I will do it, but this board has always had terrific resources so I thought I should check here first.
Thanks in advance,
Max
#2 avk
avk
    My Outback is bigger than yours
  • 965 posts
  • Somerset County, NJ
Posted 20 April 2004 - 08:40 PM
On the picture in the diagnostic manual, both ABS relays look like Bosch type (maybe because the system was licensed from Bosch?), with Bosch numbering of the pins. But Bosch relays come in several configurations, different in width and arrangement of the pins. You'd have to find an exact match.
#3 Max Power
Max Power
    USMB Regular
  • PipPipPip
  • 38 posts
  • Chicago, IL
Posted 20 April 2004 - 09:22 PM
AVK - Thanks for the info. I noticed the name Nippon on the relays. I wonder if Nippon makes the relays for Bosch.
#4 avk
avk
  • 965 posts
Posted 20 April 2004 - 09:32 PM
Maybe they are copies of Bosch? All the other relays in the car are different. Also, the pictures I saw were for '95 ABS, but you know what a Bosch "cube" relay looks like, so you can tell if that's what you have.
